Question about RCA HD52W56 52" Rear Projection HDTV
Help;;;;;;;;;;;;;;;;;;;; Hi, I have a green lite but the tubes wont start, have unpluged it many times for reset. Took back of, there is a screching noise comeing from the bottom board, i tracked it down two a power supply, it is a coil ,copper wire, has about 6 legs going into the board. is there anything i can do other than ordering a hole new board. the board# is266862 from rca 100$ could it be a fuse. there are no fuses there. like the old glass ones. could it be something in front or behind the flyback, ithink thats the name fo the part thats bad, or can another part make it squeel? the set is only 2 years old. ANY HELP:::::::::::: Steve
    Genius:
  • 1,030 Answers
Question #1 can you look on back and see what the chasis # is and also there is in small print a # that reads model like hd52w56....yx1 or yx5 or something like that. i need these numbers because there are certain models that have service bulliteens. also when ordering parts u need to get right parts. The sqealing from a coil usally indicates something is loading.that cuircit. you may have a component shorted. ussally when a tech hears squealing he looks at the horizontal output and flyback as the primary reason for this. Recently the prices for some of these boards have come down. and may be the best route to go.
Posted on Jan 17, 2008
Power lite on rca flat screen flashes 4 times
I would suspect either the Power supply or the main board. I can assist you with basic trouble shooting to determine which board it is if you would like. Just respond to this same post for assistance.
Jan 01, 2013 | RCA L42WD22 42 in. LCD Television
Every time I turn off the TV . It won't come back on. Just a black screen. I unplug it, turn it back on, but nothing. I unplug everything,VCR Surround sound DVD and TV. Also reset the HD box. Nothing. I...
MORE TNEN LIKELY IF THE STANDBY LITE IS ON THEN THAT MEANS YOUR PICTURE TUBE WENT OUT ... YOU CAN TELL IF THIS IS THE PROBLEM BY LISTENING TO IT ONCE YOU TURN IT ON .. IF IT CLICKS ON THEN POWERS OFF SHORTLY AFTER THEN YUP YOUR TUBE IS BURNT OUT ... IT RANGES FROM $350.00 ON UP GOOD LUCK AND PLEASE MY HELP.. THANK U
Oct 31, 2010 | Polaroid FLM-3201 Television
I cannot get power to 19
Hi there...
First check your AC Adapter, see if it still lite green. If it not then you need a new AC Adapter. If AC Adapter still lite green, then your back light inverter are busted. It's more likely your inverter are busted... I can repaired for you... for more information @ www.3rd-Rocks.com Thanks, have a nice day!
Jan 20, 2010 | Fuji FP-988D 19" Flat Panel LCD Monitor
The blinking green lite that wont go off wont allow the tv to come on tv must be reset each time sometime reset works and sometime tv off for days have to unplug from wall for couple days then replug and...
The blinking green lite that wont go off wont allow the tv to come on. We tried resetting the tv it doesn't work Also the tv has been off for days have to unplug from wall for couple days then replug and reset. It still doesn't work. Please help.
Sep 25, 2009 | Televison & Video
Tv wont turn on but green power lite flashes 3 times if i use the remote or press power button on front of tv i have unplugged tv replaced the batteries in remote trouble started 2 weeks ago if i hold...
it sounds like youre describing a RCA HDTV which needs the CP150, CP120 and CP114 repair kit. You can get that repair kit at www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Sep 22, 2009 | Televison & Video
D52W20BYX1 Green problem
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
Sep 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony laptop with dead screen
Try this: Unplug your computer from electricity, remove battery, then, press and hold the power button for about 30 to 60 seconds, leave battery out connect to power then, try to restart
Let me know if it works.
good luck
Apr 06, 2009 | Sony VAIO Notebook
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Flashing pot and pan light
shut off the power and see if the unit will reset. if its plugged in, it will be easy, look under the sink. if not, try a breaker.
let the power stay off for about a minute.
then back on.
if not restored, then you have logic boards that failed.
sorry,
good luck
mark
Oct 24, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
