Home | HP | OfficeJet k60 All-In-One InkJet Printer | I keep getting a sca...
HP OfficeJet k60 All-In-One InkJet Printer
Problem for HP OfficeJet k60 All-In-One InkJet Printer
I keep getting a scanner failure when I try to fax
By tmikell on Oct 20, 2009
I keep getting a scanner failure when I try to fax something from my all in one Officejet k60.
Solution #1
posted on Oct 20, 2009
Not Rated)
hamidquddus
Rank: Wiz  HP Expert
Rating: 79%, 11 votes
i can understand the situation here is the soluition for you :
1.TRY TO MAKE A COPY
2.if the copy does not happen open the scanner glass and check whether the scanner lamp that is tdo you see any light in the glass glowing or moving
3.if nothing gloes or move then i am sorry to say that you will only be able to print from the printer and nothing else
4.if the printer is in warranty call hp they replace it for you .............................. thank you and hope you do see the scanner lamp
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet k60 All-In-One
Questions and Unsolved Problems for HP OfficeJet k60 All-In-One
Do you recommend HP OfficeJet k60 All-In-One InkJet Printer?
Answer
Answer
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple... (More)
Answer
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has... (More)
Answer
How do I scan a document? I am getting a message that indicates that the options are not set.
Answer
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink.... (More)
Answer
Opened printer - pieces of paper stuck in roller in back - can't seem to open
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP OfficeJet k60 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
