Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
The control locked light is lit and it will not allow me to do anything else. I have pushed every button and it is not responding. How do I reset this and how did this happen? Help I need to do laundry! Thanks for any assistance. washer lights come on but washer will not lock so cycle can start The controls locked light is on and I can't start the washer. I held down all the buttons, unplugged the washer for several minutes but the light is still on. What should I do and how can I prevent this from happening again. Kenmore Elite He4t
  • Buffbaby Apr 26, 2008
    I lean on the buttons and the control lock light is lit and will not respond to anything
  • Anonymous May 29, 2008
    controlo locked light is on but no other buttons will make the machine turn on Power is on. What now.
  • 1,294 Answers
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Posted on Jan 02, 2008
  • 2 more comments
  • prem mathew Jan 02, 2008
    Click on Kenmore (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
  • sandy Jan 12, 2013
    OMG THANK YOU THANK YOU THANK YOU !!!!!! I lost my my manual and could not figure out how to unlock. i leaned against it and it locked me out . i held every button possible.....well apparently not the" drain spin " button . thanks again but now i have to do laundy ugh!! lol
  • Kathy S. Feb 03, 2013
    Thanks so much for the tip! I was all set to call a repair man, then remembered what my husband always does, and that's to check on-line for a forum. Holding the Drain & Spin button did the trick! The previous load didn't fully spin for some reason, and there was no way I could wring enough water from those dripping wet towels to toss them in the dryer. : )
  • myoung11
    myoung11 Feb 26, 2013
    Thank you, thank you! You just saved me a repair bill!
I have the same problem on a brand new washer, used one time and error F29 showed up. The door is locked. Sears sucks and I am so sick of calling them! They have ordered a part and are coming out to fix it. I have had 2 technicans out here to fix a brand new washer. If you are having the same problem, you can unpug the washer for about 5 mins then pug back in. If that doesn't work, click cancel then power. Select a cycle and hit start. Wait for the door to unlock and quickly open it before the cycle starts. It might not work the 1st or 10th time but it will eventually.
Posted on Jun 27, 2008
    New Friend:
When i use our kenmore elite the last 12-15 minutes of it's cycle it stops working and wont finish the cycle and it just flashes the number of minutes that are left and wont release the lock on the door to get my laundry out. and it does that on just about every cycle
Posted on Jun 02, 2013
    New Friend:
This actually did not work for me. To remedy this, I turned the breaker switch off then back on again. Then depressed the "Auto Dry Level" button for 3 seconds and voila, I can dry my clothes again :)
Posted on May 22, 2013
3 Suggested Answers
SOURCE: Kenmore Elite HE4t Washer - "Control Locked"
I pressed and held drain/spin and it unlocked the controls... try it and let me know.
Posted on Jan 01, 2007
I followed dpgord suggestion and held down the "Drain & Spin button" for a few seconds and it fixed it.
Thanks, you probably saved me the cost of dinner in a nice restaurant. Who knows, with today's prices you may have saved me air fare to Hawaii.
Posted on May 22, 2008
The machine's "Control Locked" light is on.
Did you try to push and hold the 'CYCLE END SIGNAL' button for 3 seconds?
May 02, 2010 | KitchenAid KHWS02R Front Load Washer
The front light lit on my Whirlpool dryer is showing control locked
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Control locked light on
First remove the plug for 5 minutes and this will reset the system.
Check to see if the light beside the LOCK ICON is lit on the status lights. If it is, then the controls are locked. Press and hold the OPTIONS and SELECT buttons simultaneously until the lock light goes out. This should free up your controls so that the washer will operate normally.If the console will not respond, then you could have a failed control or a stuck button.
Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
Adjacent to the "Control Locked" light is the DRAIN/SPIN button. Push it in and hold for 3 seconds. This should unlock the control panel. If it doesn't, let me know.
This is a designed feature of the washer to lock the controls to prevent small children from accidentally turning the washer on or manipulating the controls in any way. The control can be locked by holding the DRAIN/SPIN button in for seconds, and released the same way. If someone leans against the button this can also occur. Hopefully this will be an easy fix for you. I hope this helps.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
Duet sport dryer control lock out on
stop coumting and just hole till light goes out if still no response try cutting power then hold power button down 10-15 seconds this may drain and remaining power to control and allow it to reset ..still problem probably control issuefront interface where buttons are most likelt
Jul 16, 2008 | Whirlpool GEW9250 Electric Dryer
CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
May 23, 2008 | GE WSXH208A Front Load Washer
I had the same problem. If you will hold the "Drain & Spin button" in for approximately 4 to 5 seconds it unlocks the " Control Locked" issue.
Dec 18, 2007 | Kenmore Elite 45986 Front Load Washer
Control Locked light is on...
OMG!! I just held the button at the end of cycle signal for about 3 seconds and the light went off! Now my washer is working!
Ok Yankee
Nov 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Nov 25, 2006 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
5,526 people viewed this question
Sal De
 Brian Main
Brian Main
