Question about GE WCVH6260F Front Load Washer
Error codes???? Is there a way to check error codes on the WCVH6260FWW washer?? Thanks
  • Anonymous Mar 15, 2008
    start button light flashes and washer will not start. turned off washer for 3 hours, same problem. un plugged for same time same result.
    door closes tight as well.
    when the start button is pushed it does click but does not start.
  • Gary Davd
    Gary Davd May 11, 2010
    yes which ones??
Remove the top cover. Inside there's a service manual that decribes the error codes and how to read them.
Posted on Feb 18, 2008
2 Suggested Answers
dahaka
  • 347 Answers
SOURCE: Error codes???
Hi DMS1, your wacher might have gotten stuck with somthing. Maybe a piece of string or just dirt.
Have you already tried to open it and clean it?
Posted on Dec 29, 2007
How do I pull up error codes
Follow these steps to enter the service mode on a GE front load washer. 1. Close the door.
2. Clear current cycles by pressing the power button. Make sure the screen is blank before attempting to enter the service mode.
3. Disconnect power to washer for at least 30 seconds.
4. Reconnect the power and within 30 seconds of reconnecting power complete the next step.
5. Press signal -delay start -signal - delay start.
If you successfully enter the washer into the service mode, t01 will be displayed and the door will lock.
Here's a link to the codes: http://www.appliance-repair-it.com/GE_front_load_washer.html
Good luck with your troubleshooting!
May 28, 2014 | GE WCVH6260FWW
Error codes???
Dec 29, 2007 | GE WCVH6260F Front Load Washer
No hot water cycle on ge wcvh6260fww
You need to replace the water inlet valve. Here is the part to order.
I have the complete service manual available if you should need it, post your email address.
Feb 17, 2013 | GE WCVH6260FWW
Duet GHW9150P Front Load Washer: what does the F14 error code mean?...
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F 11 error code on whirlpool duet washer.
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
this is for error code f 11
thanks.
May 02, 2009 | Whirlpool GHW9400 Front Load Washer
GE WCVH6260F Front Load Washer Logo
402 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
