Question about Pioneer DEH-P840MP CD Player
Repair no.3 This repair--rear display doesnt light up...it does move...so the cd player works..however the ability to tweek the system is no more due to this problem....i was able to get by for several months...but i put a new battery in, and id like to tweek the system back to par. --i realize there were more posts similar to mine but i am on a dialup connection....enough said I appreciate your help Craig
  • 47 Answers
REPLACE THE RIBBON CABLE IN THE FACE PLATE
Posted on May 13, 2008
CD STUCK IN PLAYER COMPUTER STUCK INSIDE DOESNT COME OUT
Here are few ways at this link:
10 Ways To Eject Stuck CD or DVD from MacBook SuperDrive Raymond CC
It depends on whether the CD is stuck due to a process or if it is physically stuck. If none of these work, I would advise taking it to a repair facility.
Nov 29, 2014 | Computers & Internet
Panasonic cd stereo system error
It sounds as though the eye that reads the cd's has stopped working, unfortunately due to its age you maybe out of luck, try local repair people in your area or search further a field to specialist repair persons....
I think that this maybe futile, but it's always worth asking for advice from local repair person....
I hope this helps.....
Feb 22, 2018 | Audio Players & Recorders
Since I purchased my 2009 dodge journey I have had an issue with my radio/cd player ... sporadically the volume goes out, if I turn it off, and on it comes right back on, but will only stay on for 20...
AUDIO Any diagnosis of the Audio system should begin with the use of the scan tool. For information on the use of the scan tool, refer to the appropriate Diagnostic Service information.
For complete circuit diagrams, refer to the appropriate wiring information.
AUDIO SYSTEM DIAGNOSIS
CONDITION
POSSIBLE CAUSES
CORRECTION
NO AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Amplifier fuse faulty, if equipped. 1. Check and replace fuses, if required. 2. Wiring to amplifier faulty, if equipped. 2. Verify radio on/off input to amplifier and verify battery and ground connections. Repair wiring as necessary. 3. Radio faulty. 3. Refer to appropriate Diagnostic Service Manual. 4. Amplifier faulty, if equipped. 4. Replace amplifier. NO AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speaker(s) faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty.
5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Power/ground wiring to amplifier open or shorted. 1. Repair wiring as necessary. 2. Power/ground wiring open or shorted. 2. Repair wiring as necessary. 3. Amplifier faulty. 3. Replace amplifier. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speakers faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty. 5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. SOUND DISTORTION (VIBRATION FROM SPEAKER AREA, BUZZING - HUMMING) 1. Door trim panel loose or missing fasteners. 1. Inspect door trim panel and correct as necessary. Replace any missing fasteners. 2. Water shield loose or misaligned. 2. Inspect water shield and adjust as required. 3. Items placed in door trim panel map pockets vibrating or moving from side to side. 3. Remove items from door trim panel. Ensure that vibration is no longer present. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE OPERATIONAL 1. Radio faulty. 1. Refer to appropriate Diagnostic Service Manual. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE NOT OPERATIONAL 1. Fuse faulty. 1. Check radio fuse and Ignition-Off Draw (IOD) fuse in Junction Block (JB). Replace fuses, if required. 2. Radio connector faulty. 2. Check for loose or corroded radio connector. Repair, if required. POOR RADIO RECEPTION WITH KEY IN ACCESSORY OR IGNITION ON POSITION 1. Antenna faulty. 1. Replace the antenna. 2. Radio ground faulty. 2. Check for continuity between radio chassis and a known good ground. There should be continuity. Repair ground, if required. 3. Radio noise suppression faulty. 3. Repair or replace ground strap as necessary. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. 5. Faulty rear window defogger. 5. Verify that the rear defogger grid is functioning properly, repair as necessary (Refer to 08 - Electrical/Heated Glass - Diagnosis and Testing). NO COMPACT DISC OR DVD OPERATION 1. Faulty CD/DVD. 1. Insert known good CD/DVD and test operation. 2. Foreign material on CD/DVD. 2. Clean CD/DVD and test operation. 3. Condensation on CD/DVD or optics. 3. Allow temperature of vehicle interior to stabilize and test operation. 4. Faulty CD/DVD player. 4. Refer to appropriate Diagnostic Service Manual.
Nov 01, 2017 | 2009 Dodge Journey
My philips gogear ariaz mp3 player is showing file system error and it is not displaying further.
1. try reset.
2. If 1 doesnt work, try fw upgrade
3. if 2 doesn't work, try to do repair function by using device manager
4. still doesnt work, i m afraid you hv to send it to repair centre ( pls be reminded that u hv to bring purchase invoice) :)
Nov 15, 2010 | Philips GoGear Ariaz MP3 Player
Dear Sirs, i have the cd changer balupunkt cd-changer a08 working however whenever i put new cd it doesnt play it only says cd error i have tried several ways of making the cd windows media player, nero...
Plays some does not play others. Soon nothing will be playable. Laser assembly losing ability to focus properly on disc surface and it has to be replaced since repair is not cost effective with these things.
Aug 31, 2017 | Blaupunkt CDC-A08 10-Disc CD Changer
When disc is inserted it says 'unknown disc'
one particular disc? or all discs?
Unplug for 5 minutes and re-try.
Thanks
Jan 03, 2010 | Alba DVD55 DVD Player
Message center displays "CD Changer Error" Won't play music, or display mileage info
reset the computer by disconnecting the battery for 30 minutes.
If that doesnt work you will have to take it for repair. the dealer is very expensive on this, my experience is it is cheaper to take it to a audio specialist who is cheaper and will do a better job.
Oct 08, 2009 | 2004 Chevrolet Malibu Maxx
CD is not playing on my SONY Home Audio CMT-EH15
HI. that grinding sound is signaling a lens assembly issue. the linkage and gear assembly seems to be jammed. this assembly must be able to move freely i order for the lens to track the CD. if the lens assembly is stripped or jammed, it will not be able to read and it will shutdown into stand by mode to prevent the motor from damaging itself. its most likely gear failure.
Unfortunately, the repair parts for this unit are only available from sony repair depots and, you will need to contact sony manufacturing in order to receive a repair ticket.
May 19, 2009 | Sony Audio Players & Recorders
NAD 502 CD player LCD problem
hey, well, typical problem i nad cd players, and also receivers by the way. The proble are tha nad use standard glow lamps. And as we know, the blow!! And often when you move around with the cd. Well i do have repair note for this one also. http://www.miguelovitch.dk/ go to the menu: 'amplifier repair notes' (yes includes cd players ;) ) Here you can find free amplifier repair notes, an go fore nad 705 repair fix (same fault with defect bulb's as in you nad cd) And also a technical repair movie showing you the hole process of the 'workaround' this fault i NAD 522 (NAD 501, 502, 512 and more) http://freemovies.s-educator.org/repair_movies/nad/nad_cdplayers_defect_lamp_in_display_stremingvideo.html best regards michael miguelovitch
Sep 06, 2007 | Audio Players & Recorders
Pioneer DEH-P840MP CD Player Logo
55 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
