Bosch Nexxt® 500 WFMC3301 Front Load Washer
Problem for Bosch Nexxt® 500 WFMC3301 Front Load Washer
I have Bosch Nexxt 500
By sshin1515 on Oct 20, 2009
I have Bosch Nexxt 500 Washer. It stops draining and flashes E04 error. Any idea what is causing it or how to troubleshoot and repair?
Best Solution
posted on Oct 23, 2009
Very Helpful)
57 varieties
Rank: Guru  Bosch Washers & Dryers  Expert
Rating: 88%, 533 votes
The error indicates that the machine has taken too long to drain the water. Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
  3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Bosch Nexxt® 500 WFMC3301
Questions and Unsolved Problems for Bosch Nexxt® 500 WFMC3301
Do you recommend Bosch Nexxt® 500 WFMC3301 Front Load Washer?
Answer
Answer
My 2.5 year old Bosch Nexxtg 500 WFMC3301/UC washing machine fills then drains. Does not complete... (More)
Answer
Water will not drain from the machine. We washed a bathmat with a rubber backing and it came apart.... (More)
Answer
my softner is full of water after a laundry cycle, why is that?
Answer
After putting on a normal wash cycle, approximately 10 minutes into the wash, a beep comes on (quick... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch Nexxt® 500 WFMC3301...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
