Question about Philips CDR770 CD Recorder
Does not record
The recorder doesn't record. I have followed the instructions to the letter. I get to the point where the Record light stays on indicating that it is recording but after about 20 seconds the record light goes out and I get the the word "Busy" for a second and then the letters "UPDREE" appear. The manual says that it means "updating disc contents". At that point that word goes away and the recorder stops. Any advice?
  • 112 Answers
Re: Does not record
Have you selected the correct input? These recorders are desinged to stop after 20 seconds of silence. Do you get any level showing on the record level meters? Press the source button until it shows 'analogue' if recording to the 2 phono inputs.
Posted on Jan 15, 2008
0 characters
3 Points
How do I fix my rowe juke box?
Sensor circuits for locating specific records has gone south.
Did you contact Rowe for assistance?
Sep 25, 2015 | CD Players
Wurlitzer lyric wont play after selection
my lyric selects the record and plays but wont reste at the end the needle just stays there and it keeps spinning??
thanks craig
Apr 16, 2012 | CD Players
After i have finish recording and i am finalizing the the cd code OPC appears on the screen, and being finalize the cannot play in other cd player why?
OPC means the unit had trouble Optical Processing Calibration, which means the disc surface may be damaged. Using brand name media and being careful to not touch the recording surface would help.
It's not completing the finalization so it won't play in a CD player yet.
It's mostly in the manual
OPC: Stands for Optical Processing Calibration.
When you see this message in the Information
Display for the Record DeckK, it means
that the laser transport inside the unit is making
the calibrations and adjustments needed so that
the recording process is optimized for the specific
disc in use.
When an unfinalized CD-R or CD-RW disc is
placed in the Record Deck%, the letters
OPCwill flash once the Table of Contents has
been read. This indicates that the unit is optimizing
its circuits for maximum compatibility with
the specific recordable disc in use. the number
and total running time of any tracks that have
already been recorded will appear in the
Information DisplayK, and the appropriate
indicator SPwill light to tell you if a CD-R or
CD-RW disc is in use.
To Finalize a disc, place it in the Record
Drawer%. Once the disc's Table of Contents
information has been read and the OPC process
has been completed, press the Finalize button
E@and note that the Finalize Indicator
Uwill begin to flash. Within three seconds,
press the Select button9*and note that
the Finalize IndicatorUwill stop flashing.
The Finalization process will take up to two
minutes, depending on the length of material
recorded on the disc. During the Finalization
process the Record Deck will not accept any
operating commands.
Dec 29, 2010 | Harman Kardon CDR20 CD Player
Got an RCA CDRW 140 Dual Disc Recorder but there was no manual for it. How do I record from a Disc with music on it to a blank disc?
Search rca website for instruction manual or just google the model number followed by instruction manual
Nov 10, 2010 | RCA CDRW120 2-Disc CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
It is not recording. I press play then I record. When I am finished I press stop. I then press finalize then record. But it does not record. Am I following the proper recording sequence?
Don't you have the manual?
Press REC and the RECORD indicator will start flashing when the unit is ready to record. You can set your levels for an analog input by playing it while in this mode.
When your source is ready and you have your levels set up, press PLAY on both units.
If you don't see the time incrementing , it's just standing still.
Apr 20, 2010 | Philips CDR870 CD Recorder
Anytime I try to record with my HHD BurnIT cdr 830, the red record light will only be bleeping and the time counter will not work as well. And there will be nothing recorded on the cd.
Just a guess, but did you ever try to hit the record a second time once you're all set up to start? The first press of the record button places the machine in record/pause mode after it calibrates itself to the disc.
Jan 19, 2010 | HHB BurnIt CDR830 CD Recorder
Recording favourite tracks
After bookmarking the selected tracks and you are ready to copy them to the HDD, make sure the bookmark abbreviation is lit up in the display. All you have to do is press the bookmark button on the remote or on the recorder- after pressing "copy" but before pressing play.
May 15, 2008 | Yamaha CDR-HD1300 CD Recorder
Philips CDR770 CD Recorder Logo
160 people viewed this question
Top Philips CD Players Experts
Colin Stickland
Colin Stickland
Are you a Philips CD Player Expert? Answer questions, earn points and help others
