Question about 2wire HomePortal 1000HW DSL Modem and Network Router -1000-400210-000_LN_R (1000400210000LNR)
Lost Ethernet and Wireless Connections in Modem
Using 2Wire Home portal 1000HW modem with Verizon service.
My daughter attempted to connect using Linksys wireless-G Broadband Router Mod# WRT54G. I am not sure what settings were changed, but we can no longer access the settings page http://gateway.2wire.net to change settings back. I have a steady orange Local Network light on modem. 4 computers: (1) USB connected; (1) Ethernet connected; (2) Wireless connected. The only computer that can still access internet is the USB connected. There is no reset button and disconnecting the modem and reconnecting does not reset. Help???
  • 4 more comments
  • vampyre Dec 29, 2007
    192.168.0.1 does not work - can't connect to page. There is no link posted on your comment for router's manual. Thank you for trying, would appreciate any further assistance you may have to offer.
  • vampyre Dec 30, 2007
    I purchased the modem when I had SBC DSL, it was not provided by Verizon.
    Tried 172.16.0.1 with same results - cannot connect to page.
    ipconfig /all information:
    Node type Broadcast
    IP Routing enabled No
    WINS Proxy enabled No
    Physical address 00-0D-72-32-44-3A
    Dhcp enabled Yes
    Autoconfig enabled Yes
    IP Address 71.126.200.37
    Subnet Mask 255.255.255.0
    Default Gateway 71.126.200.1
    DHCP Server 71.126.200.1
    DNS Servers 68.238.96.12 and 68.238.112.12
    I tried the default gateway # with same results - cannot display page. The idiots that built this modem have all settings config on the internet gateway.2wire.net page rather than having a reset button. Everything I have read on the internet so far all leads back to the settings page which doesn't help if you can't access it. Thanks for the input - if you find any other info Please let me know.
  • vampyre Dec 31, 2007
    Original cause of problem: The routing functions were disabled in Bridge Mode.
    As it turned out, you can only access the modem if the IP address on your computer is in the same subnet [ex. if the modem is at 172.16.0.1, then your computer's IP must read something like 172.16.x.x (numbers marked x making no difference)] or the computer can't find the modem to change the settings, even if you type in gateway.2wire.net.The Subnet Mask address must also match the modem. After these settings you can access the page to make the changes, and modem is back up and running fine now.
    Thank you for all your help, and have a Happy New Year!
  • nimbus3 Apr 07, 2008
    I cannot seem to connect with any browser.  I think I need the correct DNS addresses but don't know where to get it.  I am using
    DHCP
    IP 172.16.1.35
    Subnet 255.255.00
    Router 172.16.0.0 (not sure about this but my MAC is using .1 on the same network.
    Don't know what my DNS addresses should be??
  • Anonymous Mar 17, 2014
    can't connect to local network, on television but can on laptop. Have tried disconnecting router and modum and reconnecting...no change What now?
  • Anonymous Mar 26, 2014
    How do I change the network name from 2wire### to anything I like?
    I tried going into the router's settings:http://192.168.1.254/xslt?PAGE=C_2_1_POS...
    and changing it there. It shows successful and then stays the same name of 2Wire### rather than my name (say customName)
  • 205 Answers
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Posted on Dec 29, 2007
  • 2 more comments
  • ohiotom Dec 29, 2007
    Sorry I forgot to past the link. Here it is:
    http://www.2wire.com/pages/pdfs/2Wire_10...
    I'm finding a variety of things on the web about this modem. Was it provided by Verizon?
    Please try this address 172.16.0.1 and see if that get's you to the router....we'll get eventually.
    Just found something that might help...
    On the computer that is working with the internet do this:
    Start->Run
    Type this in the box:
    command
    A window will popup and it will look like the old DOS interface. At the C:\ prompt type this:
    ipconfig /all
    Look at the IP address listed next to Default Gateway. This should be the IP address of the router.
    Let me know.
  • ohiotom Dec 30, 2007
    Very strange. The fact that your IP address and Default Gateway are in the 71.126 range seems odd. The default settings for this router should be something like 192.168 or 172.16
    If you feel like trying some more things please do this: go to each computer on your home network and repeat the ipconfig /all step. Do you get the same default gateway on each computer? Also while the command window is open type the following: ping 71.126.200.1 If the Default Gateway on the computer is shown as some other IP address use the appropriate address in each case.
    Another thought I had was your firewall software. Just as an experiment have you tried disabling the firewall and then connecting to the router? And I'm assuming you're typing http://71.126.200.1 in the Address bar of Internet Explorer when you're trying to connect, is that right?
  • ohiotom Dec 31, 2007
    Good news.
    Thank you for the rating.
How to access your wifi password with 2wire homeportal 1000hw
If you have the setup menu login password you can view (and change) the wireless connection password in the modem setup menu. You'll need an ethernet cable to connect directly to the modem if you can't get to it wirelessly. With the ethernet cable you bypass the need for the wireless password but you will still need to get into the configuration menu, which usually has a password too. After you connect the ethernet cable, open a browser window and enter 192.168.1.1 in the address field and press enter. This is the same web address field you would use if you were typing www.google.com. That 192. address should take you to the modem setup menu. If a password is required it will prompt you to enter the password. If you don't know the password you'll have to reset the modem and start over. (yes, there is typically an actual reset button although many of them are hard to find) After a reset there is usually not a password requirement. Make sure you set all passwords again if you do a reset - want to be sure no one else can get into your router once you are finished.
Sep 19, 2010 | 2wire HomePortal 1000HW DSL Modem and...
I have moved to new home. I am using 2wire wifi
you can check if the ethercable is loose or if you have a spare ethernet cable (rj45) you can replace the one that youre using
Jul 14, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Had a thunderstorm, looks to have disabled RJ45 connection
Do you have a ethernet checking device? (Lowes and Home Depot both have several devices - price in the $50 to $75 range.
You could replace the two ether net cables and see what happens.
let me know what you find out
a
Oct 02, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I want to identify hardware.
Here is description of the unit , the installation guide and the user guide:
HomePortal 1000HW Router/Modem with Firewall & 1 Ethernet port, highpowered 400mw 802.11b wireless, USB, and HPNA.
2Wire HomePortal gateways include an array of the most common home networking technologies accommodating a variety of service provider and subscriber environments. Flexible networking options include high-powered 802.11g wireless, Ethernet, HomePNAv3, MoCA, and USB.
http://www.2wire.com/pages/pdfs/1000_series_Gateway_Install_Guide.pdf
http://www.2wire.com/pages/pdfs/2Wire_1000_User_Guide.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 30, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Unable to set 2wire wireless connection with my PC
connect a cable modem to it take out thwe existing ethernet in the cable modem put in the 1 that u have with ur new 1 put it in the cable modem put the other end in the first port of the ethernet ports take the 1 u took out of the cable modem and and it put it in 1 of the thernet ports all the light should go green then try wireless.
Feb 25, 2009 | 2wire HomePortal 1000HW DSL Modem and...
2wire homeportal 1000hw cannot find wireless address
Windows 7 (Beta) and Windows Vista 64 Bit. Step 1. Do not allow the autostartup to run the installation application. You must right click on the CD ROM and select the "OPEN" option. Locate the driver on the install CD. Since my DVD ROM drive is my "D:" drive I located the driver at D:\USB_VISTA32364\BACKUP_2WIRE_VISTA_USB_Installer.exe . Before you click on this you want to right click on this and select Properties. In the properties tab click on the middle tab marked "Compatibility". Make sure you select the checkmark box to: Run this program in compatibility mode for: and use the pull down menu to select Windows XP SP2. This is how I was able to get my 2wire utility to work on Windows 7 (beta) 64 Bit.
Feb 07, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Installation problem
YES!!!!! IT DOES NOT HAVE TO BE A SPECIFIC ETHERNET CORD TRY A REGULAR ONE OUT FIRST IF IT DOES NOT WORK IT WON'T SCREW ANYTHING UP IT WILL STILL BE WORKING JUST FINE SO JUST TRY A REGULAR ETHERNET CORD
Dec 14, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Connect panasonic bl-ca10 cam to a 2wire home portal 1800g
Try using WEP instead of The WAP protocol.
It worked for me.............
Jul 06, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Home portal not yet activated
XP is an very good OS which will connect with 2wire without any problem.
If your computer is not able to detect modem, pls follow these steps.
* Check for damage of ethernet cable
* Try to reset the modem by using a paper clip punching into the reset button
* Even if your modem is not detected, force the IP and Default gateway
Take care
Feb 26, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Computers & Internet Logo
358 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
