Question about Hitachi 43FDX01B TV
HITACHI PROJECTION MODEL53FDXO1B CONVERGENCE PROBLEM
Have a tv with double image and unable to adjust the convergence bars.Tried cleaning the dust from the rear from the circuit board.It has ICSTK392-110.wHEN I TURNED THE TV ON, i WAS ABLE TO ADJUST THE CONVERGENCE BUT IT MESSED UP WHEN I SWITCHED TO A CHANNEL.hEARD ABOUT IC AND RESISTORS GOING BAD BUT NO IDEA WHICH ONE.How difficult is it to replace ics or it there any other solution.Any help will be appreciated.
  • clemper Jan 13, 2008
    Thanks for the info Terryfic.Had already ordered the convergence amps stk392-150 fro B&D enterprises.Replaced the ICs and had to do a little fine tuning on the grid bars.Picture looks fine .Saved some money ,gained some knowledge and got some soldering practice.
    Genius:
  • 1,694 Answers
Replace both IC's with Hitachi upgrade STK394-160E PART #
CZ 01341....about 30.00 each....check resistors near IC's...
can be bad 2.2 2W, for example......................T.
Posted on Jan 03, 2008
Why does my hitachi rear projection tv has double image?
Are the double images different colors, such as red or blue or green? If so, the projection unit is "out of convergence, meaning the images are not superimposed on one another. That requires a convergence generator, also known as a video alignment generator.
Apr 28, 2017 | Hitachi Televison & Video
I 53" Hitachi Projection TV and I get double
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2011 | Hitachi Televison & Video
Picture has double images around the edges of the viewing area.
Firstly check for correct colour registration at centre of screen. Look for coloured halo around white edges in centre area of picture. Use static convergence adjustment if necessary to correct centre of screen. Then follows an involved process of interactive adjustments to attempt correction of errors at the screen extremities. If these are out of adjustment range this is indicitive of a convergence drive fault requiring professional intervention.
I hope this information is helpful!
Jan 01, 2010 | Hitachi Televison & Video
I have double image I am looking at array but not
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 05, 2009 | Hitachi 50DX20B 50" Rear Projection...
Getting double images on screen like outlines on images
Your TV has a failure of its convergence output ICs and perhaps some of the convergence circuit's other associated parts. The part numbers for the ICs are on the IC face. They can be purchased thru Hitachi or online at MCM Electronics.
Feb 10, 2009 | Hitachi 51F510 51" Rear Projection...
Double image
Problem seems in convergence out section.
TV needs Convergence Out ICs replacement.
If you have TV repair experience and know good soldering work then you can give it try OR get help of qualified TV tech to fix it.
If you need further help, let me know.
Dec 30, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Hitachi Mo# 53uwx10ba double image
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Blurry double image on the edge of the tv...
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Apr 16, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Replace both IC's with first quality Hitachi upgade STK394-160
part # CZ 01341 and inspect near-by resistors for over-heating.
.......................T.
Feb 15, 2008 | Televison & Video
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
  • Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Dec 03, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 43FDX01B TV Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
