Question about Kenmore 63942 Dryer
The only thing that can burn in a drier is lint most of the time if lints building up in a drier depending on age its because of poor venting if the drier heats but it takes longer than an hour to dry clothes you have a vent restriction but every few years you should take it appart and clean it out now kenmores drums run on rubber wheels and like a car they get flat spots in them so they roar and bump when they first start but should get quiter as you run more loads during the day
Posted on Dec 29, 2007
I have a Kenmore H2E dryer model 110.87562602. I don't know what happen but smell burn. the panel control is working well but dont start
burning smell good be a lot thing wrong with your dry .if u know how to take front panel off are the dryer may have a bottom access panel be fore u do any thing unplug dry are turn the power be safe are call a appliance repair tech to fix the dryer for u ok .
Jun 13, 2017 | Kenmore Dryers
Dryer smelled like something was burning and turned off. What could it be ?
Need to have your Dryers Cabinet area cleaned like Now having a Possible Dryer Fire
Sep 15, 2014 | Kenmore Whirlpool Dryer Gew9868kq0 Light...
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Dryer smells like something is burning. Heard a snap but checked the belt and it is intact.
The burning smell usually comes from an overheating motor. Onces it heats to a certain point, it will trip the thermal switch on the motor. Motor should be getting around 11 amps. Best of luck :)
Sep 13, 2009 | Kenmore Dryers
Dryer got very hot and smelled burning..
This is usually a result of a stalling idler pulley or drum, causing a burned spot on the drum drive belt.
The situation will only worsen. The belt is best replaced before it breaks.
Items to pay attention to, when the drum drive belt is replaced, are:
(1) Clean and lube the idler pulley and drum roller shafts.
(2) Confirm that the drum glides will yield additional service life.
(3) Check motor condition and de-lint the blower housing and blower intake pathways.
Sep 07, 2009 | Maytag Dryers
How do you check the belt?
You will have to lift the top to check the belt and also for access to change it. Burning could also be lint or wires so if it was not the belt make sure you find the reason and repair that carefully.
Jun 08, 2009 | Kenmore 63942 Dryer
Kenmore 800 dryer burning smell and noise.
Access is from the front. Lint screen on top? 2 screws under screen, putty knife to release front clips between top and cabinet. Top folds back and 2 5/16 screws in top corners. Lean front towards you then lift up off lower hangers. Good luck.....
Jun 06, 2009 | Kenmore Dryers
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 63942 Dryer Logo
176 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
