westell 6100F: dsl lite on ,internet lite blinks/steady, data light out and stays out, no internet, no network device or dsl modem in device mgr, called verizon they said my network card is bad, took pc to store and network card is ok , called verizon again they said to use usb connector at pc end of ethernet cable instead of ethernet conn dont have pc back yet from store but will this solve the data light and no internet problem when i get it home? Thank you, John
Try a different ethernet cable. It could be that your cable is bad. I had that happen to me before. My was from the modem to the router. If it was working at the store and not at home, then it is cable. It is should bea cheap fix.
I used a shiro ethernet modem And a aztech HL 109 RN wireless/wired router with Homeplug function....
(More)
I used a shiro ethernet modem And a aztech HL 109 RN wireless/wired router with Homeplug function. after surfing the net for a while i will not be able to connect up the net. I will have to shut down my modem for a couple of minute then on it again in order to regain connection. I have change a couple of modem already but same problem re-surface. Please advice.
i have a Westell VersaLink Model 327W and the light for the ethernet cable keeps blinking...
(More)
i have a Westell VersaLink Model 327W and the light for the ethernet cable keeps blinking && my computer doesn't connect to the internet. i tired putting the ethernet cable into the other jacks on the modem but it keeps blinking and still doesn't let me connect to the internet. i also tried using a different cable && i still have the same problem. someone helppppp!!! O_O.
umm well my verizon dsl internet light blinks and when i play games they lose connection or lag but...
(More)
umm well my verizon dsl internet light blinks and when i play games they lose connection or lag but on the conputer its fine
