Question about Cobra PR-245/2 (7 Channels) 2-Way Radio
Cobra 142 base
No transmit no recive meter lights don,t burn chanel lights do burn
    Problem Solver:
  • 7 Answers
I don't know this radio individually, but heres the common thing that happens:
Sounds to me like the 8 volt regulator chip has blown after overvoltage. I expect the power supply has gone too, putting 18+ volts into the radio.
Repair the power supply. (Check its 13-13.8 Volts).
Then check the regulator (7808) is putting out anything, should be middle pin ground then 13V one side and 8V the other, if nothing, its blown. Replace it if gone.
Hopefully thats all thats gone and it should work again.
Posted on Dec 29, 2007
RE Cobra 29 lx camo cb antenna warning
get a frequency counter and check to make sure you are on frequency.reset your SWR Recheck the pll section and the frequencymake sure everything is soldered good ,no cold solder joints.Could be a bad crystal or a bad IC .Check for power ratings on the PLL. If they are good your radio should be ok
May 10, 2016 | Cobra Radio Communications
No audio transmit or recive
check your final for voltage, work your way from IC 1 on up then check audio transistor . Work your way through the transmit section then the receive section . Check your volume control ,make sure its working alright Just have patience and it might jump right out at you.
Dec 15, 2015 | Cobra 25 WX-NW-ST 40-Channels Base CB...
Cobra 39LX blows TR15 and R58
When you replace only burned or damage parts, you should use a good meter an check all parts around them. Many times the part destroyed is just part of problem. Its going to take a service tech to really go over it now. Caps an resistors go bad when you have parts burned. Not much one can tell you without seeing it
Jan 16, 2014 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a cobra 148gtl it will not recive or transmit but it does light up
hello from my experience of this problem you will have to replace the audio and pa trancisters
Jan 07, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Getting regular cb chanels
go to to radio information go to corba radios and you will find the mod for 11 meters.
Jan 01, 2009 | Cobra 150 GTL DX Base CB Radio
Low transmitting range on Cobra MRF55
Hi dstrand, sorry you are having a problem. I will need some more info if you can. Is this radio in a base situation or mobile? Have you had any work don recently? Have you changed anything on the system? (Microphone, antenna, coax, etc)
Haave you checked your swr recently/ If yes, did you use a seperate meter or did you use one built in the radio?
Hope to hear from you soon.
Dec 30, 2008 | Cobra MR- F55 Base CB Radio
No recieve on virgin cobra 142 gtl,
seems to me that the audio ic of the cobra 148gtl brokedue sudden change of voltage from power suplly or flactuation. ta7222p
Jun 07, 2008 | Radio Communications
Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
Aug 16, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra PR-245/2 (7 Channels) 2-Way Radio Logo
96 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
