Question about RCA F27252GY 27" TV
Remote control issue
Have not used this tv for a while. What does the remote for this thing look like. I have lots of remotes and can't figure out which one should work.
    Problem Solver:
  • 14 Answers
For starters what brand is it? just match the brand remote up with it.........otherwise, go buy a universal remote:P
Posted on Dec 29, 2007
My remote control on my 37 lcd tv will not work
I also had this problem.. Try this
Turn your tv off at the wall without putting it on standby.
Leave 30 seconds then switch back on.
At the side of the tv is a menu button, press and hold it for 15 seconds.
Now press the menu button on your remote control.
You should now be able to use the remote.
Jun 15, 2010 | Televison & Video
Out of nowhere my remote won't turn on my directv box when the front of my wall unit is on. It will work when the front of my unit is off. what can i do?
Ok well I am going to assume that by 'wall unit' you mean your wall-mounted TV. This issue is most likely caused by a combination of two things.
1. The Harmony remote's IR emitter is becoming weaker. This can happen as the remote gets older, the IR signal is not as strong as it was when the remote was new.
2. Your TV is very bright, causing a lot of IR interferance. I suspect that this is the main issue here, since you indicated that the remote works OK then the TV is off.
Try dimming the amount of light that is coming from the TV (if possible) and dimming the lights in the room. Remember, the more light in the room when you are using the remote, the less strong the remote's IR signals are going to be.
Mar 24, 2010 | Logitech Harmony 550 Remote Control
LG LCD TV volume/sensor problems
it could be 2 issues: faulty remotes or stuck buttons on tv's keyboard. Where did you get 2 remotes? cable or directtv boxes? those are universal and must be programed to work with tvs. or, do you have 2 identical LG remotes in your household? either way, if you have kids on premises and lot of drinks carried around, remotes could be contaminated with fluids inside and malfunctioned. You must become a CSI and figure it out!
Good luck and let me know the results.
Alex's tv.
Feb 22, 2010 | LG 37LG30 37 in. LCD HDTV
Need instructions to program DVD Rec.Remote
Get the manual or figure out from LG's website about the thing,the site should have a download of the manual for the thing
Jan 03, 2010 | LG Electronics/zenith 6710t00008 Remote...
Remote doesn't work, installed new batteries also.
Is there another one in the house? The best thing you can do is to first figure out if the issue is with the remote or with the MIR-600. (use one remote on that dimmer, another dimmer - than a second remote on that dimmer, and another dimmer - does the issue stay with the dimmer or the remote)? Regardless, there tech support center can help you out pretty effectively at 1-800-523-9466
Sep 30, 2009 | Lutron MIR-600 Remote Control
Remote does not work for first 5mins when tv is turned on
There are a lot of possible culprits that may be causing this i.e . light source between TV and remote usage location, sunlight infiltrating into the pathway etc. However the easiest solution may be to have a technician come out and troubleshoot the issue. You may opt for a IR/UHF converter which is easy to connect and allows you more versatility with the remote. Thanks for using Fix Ya.
Sep 24, 2009 | DISH Network IR Remote Control
Remote code for RCA 40FHD41
Philips Universal Remote SRU4208WM/17 works with this TV. You must use the learning feature.
Aug 27, 2009 | Universal Remote Control DIRECTV Universal...
Sanyo mts stereo tv purchase in 1998
Must have original remote with Sanyo. Go online for search to Sanyo customer support
Dec 24, 2007 | Sanyo DS32920 32" TV
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
Oct 02, 2007 | Televison & Video
RCA F27252GY 27" TV Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
