i have a ps3 and when i try and connect it, It wont let me and i dont no my ip address or subnet mask or default router or primary and secondary DNS can someone help me and im using wireless
To make things easy, you can set your Playstation 3 to obtain all the
network information automaticlly. All you would need to provide is the
SSID (Name) of your wireless network and the encryption password (if
you have one enabled).
On Your PS3:
"Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit. "
Can I use GLB 802C for my DEll laptop wirelessly? I have connected with ethernet wire and I get...
(More)
Can I use GLB 802C for my DEll laptop wirelessly? I have connected with ethernet wire and I get connected but cannot get connected wirelessly. Further DATA light does not get stable green light. Can you help?
Hi, I have a Dlink DSL G604T which is working fine on the internet but will not allow to print from...
(More)
Hi, I have a Dlink DSL G604T which is working fine on the internet but will not allow to print from remote laptop have run all set up wizards so thought maybe in router settings. Cheers, John.
