4E1 35 I have a 4E1 35 wall heater and the Thermostat needs replacing.
  • 288 Answers
O.K. is there a question here?
Posted on Dec 31, 2007
Goodman wall mount heater not working
What type of thermostat digital or manual, if distal try to pull off front cover n see if that turn it off if it does this means u have a bad thermostat n needs to be replaced. If it's a manual then try to disconnect white wire on w screw ,of course turn power off to heater , and see if that turn heater off if so replace thermostat. Hope this was helpful.
Dec 28, 2013 | Goodman Heating & Cooling
My cadet wall heater wont turn off
My cadet heater was doing this so I pulled it off of the wall and saw that the two wires coming from the thermostat portion had melted out of their insulation and were crossed. The heat is of some concern, but for now I just wrapped them in electrical tape to insulate them better against melting
Mar 11, 2012 | Cadet Manufacturing Built-In Wall Heater
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
Jun 21, 2011 | Heating & Cooling
Wall heater will not work, even with thermostat in on pisition
Your thermocouple may be shot.
Have ya try to replace that one?
A simple thermostat now let me show ya a video of a man that has replaced his thermostat. Even though that gas valve is a bit different the thermocouple does the same function and that is hold down the safety magnet. Now watch:
Replace that thermocouple on your heater.
Feb 18, 2011 | Williams (5009622) Ceramic Gas Wall...
One of the thermastat wires attaching to the williams heating on the wall became loose from the screw and didn't seem to be making little of no solid contact like a car battery might due. i tightened the...
If it touched a grounded metal surface, it is possible, leave the wires hooked up at the furnace, pull the thermostat off of the wall, disconnect the 2 thermostat wires, and then twist them together, the furnace should fire, if it does, then the thermostat is shot. Replace the thermostat, usually when there is a short, it burns out the heat anticipator on the thermostat.
Good Luck,
Paul Gibson
Apr 03, 2010 | Williams 1403622 Gas Compact Heater
What is easy way to replace the thermostate in
Hi, that thermostat should be a wall mount. This heater has only 2 wires and any "Heat only", "millivolt" thermostat will work. Remove the old T-Stat and mount the new one on the wall, only 2 wires and less than a volt so no shock danger, doesn't even matter which wire goes where. Good luck and comment back if you need any help.
Jan 09, 2010 | Cozy Heating & Cooling
Wall mount thermostat not shutting off
Replace the T-Stat. They go bad after awhile and then you just need to replace the stat. When you replace the stat also check the wires to make sure they are not broken or frail.
Jan 02, 2010 | Coleman Heating & Cooling
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
Vulcan wall heater needs full service, Fawkner VIC 3060
your fan controll thermostat in the heater is not working it needs to be replaced thanks from gilles
Mar 14, 2009 | Heating & Cooling
Fahrenheat wall unit
your on-off switch is faulty - need to replace it.
Dec 07, 2007 | Fahrenheat ECP1524 Wall Mounted Panel...
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
