The computer starts and gets to the windows start up screen but goes no further. Hard drive appears to be working properly. Also will start to go into safe mode but only gets so far and won't go any further.
Sorry to say but actually your windows has become corrupted, may be due to improper shutdown or power failure. do one thing try to start your windows with previous known configuration that worked .(option already available on boot screen).if this does not work enter your windows cd and choose repair windows option when prompted.follow the instruction that proceeds.you will recover previous status of your pc.
1. Check your BIOS to be sure your computer will boot from a CD.
Enter the BIOS setup by pressing the "Delete" or F2 or "F12"
key, or as directed at the startup screen, immediately after booting. Set the
first boot device to "CDROM" or "DVDROM" instead of
"hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive
and restart the computer. When prompted, choose to start from the MS-DOS
command prompt with CD support. The MS-DOS command prompt will appear in a
moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt
and pressing enter. You don't have to run SMARTDRIVE, but copying the files
will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the
directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup.
The installation program will copy files to your computer and then display a
message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will
start again and check that your hard drive format is compatible with Windows
XP. If not, it will guide you through partitioning and formatting the drive and
then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Sorry, haven't try that yet it's a friend of mines and was just checking it out for first time. Yesturday and just haven't had a chance to do anything with it yet. I think it is just had enough, it's a Dell Inspiron 3800, I fixed it one time about a year ago put a use 20gig hard drive into and it worked fine till about a week ago. I was just going to format the hard drive and reinstall windows and see if that would fix it. I think the thing is about 10 -12 years old and the guy isn't very computer savy. I admit I am not that great with them but learning as I go. So far have been able to fix the majority of the ones my friends have asked me to look at for them. Anyway, as soon as I get a chance to see if it will boot from oe os I will let you know what happened. May be a day or 2.
Thanks
Mark Shreaves
Have you tried booting the machine with your original OS media in the appropriate drive?
