Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox convergence problem.
I replaced the infamous STK chips and 6 - 6.8ohm resistors. The issue still remains! Now it almost seems worse. I adjusted the CRT by focus but I dont think thats the issue. It must be the convergence section.
The STK chips I got do not have the same number in the upper right hand corner. Possible culprit? The chip itself is printed STK392-120, which is the correct replacement.
What do you think?
    Genius:
  • 1,153 Answers
You could be right, for more info ctechnicians.com has much info. What did your old IC's say? And did you replace fuses in that area?
Posted on Dec 29, 2007
My 60 inch Maganvox tv is blurry and the letters at the bottom are blurry. Can;t hardlt make out the picture now.
Replace STK convergence chips there are two next to the heat sink.Unsolder old and solder in the new.
May 21, 2010 | Philips Magnavox 9P6034C 60" Rear...
Magnavox rl8530 convergence is way off. how can i fix it? the image is angled and the the three colors are not aligned at all.
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 19, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51" Model # 51MP392H/17 problem.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
Convergence problems TOSHIBA TP55H60
you need to replace the convergence ic's these are the stk-xxx-xxx chips found on heat-sinks
on or around the main chassis don't adjust the tubes or anything else this will only make things worse after you replace them you can do the user alignment also check the values of the resistors in the circuit as they may be off now pay close attention to the resistors that have a value less than 10 ohms these are critical to the correct alignment if in doubt replace the resistor.
Jan 02, 2009 | Televison & Video
Tv has a the blue tint that won't line up.
the problem is with the convergence, 1 or more chips could be faulty. replacement is the oly option if faulty stk-xxx-xxx
Dec 26, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 55" rear projection tv
It is probably your convergence chip.
Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Jul 28, 2008 | Philips Magnavox 55P9271 55" Rear...
Green rainbow streak on bottom of TV PT-47Wx49E
If Convergence on setup dosen't work, And you think its not STK Convergence chips!, Then "Yes" It more then likely will have a few open Resistors!... (Near STK chips)
Jun 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence
http://home.comcast.net/~dande76530/ConvergenceOutSchematiics.pdf
http://www.servicemanuals.net/results.aspx?type=SM&brand=15&model=AV-48WP74
Dec 17, 2007 | JVC AV-48WP74 48" Rear Projection...
Convergence Problem
you nid change the [stk] of comvergency and chek the resistors tha sorce de negative -volts -28 or -30 many times thises resistors is open!good loouk [disculpa mi falta de ortografia mi primer idioma es espanol saludos!efrenhd@aol.com.
Dec 10, 2006 | Philips 7P4830W 48 in. Rear Projection...
Convergance/bowing
most like tes thats all your going to have to replace + the silicon as if you dont thet wil not last as long as they should. Also you may have blow fuseable resistors next to the ICs make sure you check them as well.
Aug 16, 2006 | Philips 9P6044C 60" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
