Question about Proview PL713S 17" Flat Panel LCD Monitor
Proview PL716s flashing on and off.
Even with no PC connected to it, this monitor just cycles back and forth from on to off and back again...
  • Wolfensmile Jan 01, 2008
    No, the issue remains the same whether connected or not. This problem started after oer a year of use.
I have a Proview PL716S and sometimes the entire
ur monitor got err i need to be changecoz repairing of monitor is unprofit
Apr 14, 2010 | Proview PL916S2 Monitor
ProView PL716s U101 roasted
I would change the caps anyway, they're cheap. The IC's may be running hot trying to make up for the bad caps.
Jan 28, 2009 | Proview Computers & Internet
Power cord for proview monitor model Por PL716S
This link will have it....http://quail.com/index.cfm?gclid=CLuglZORppgCFQu-GgodGwZmoA.RICHARDM69
Jan 23, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
Power light Flashes on and off stays blue
Hi...there,
It's seems you got a busted AD Board... your LCD bios had been damaged or erased.
Dec 01, 2008 | Computers & Internet
ENERGY SAver is stuck on
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
powerseller
bammbammfran
Sep 04, 2008 | Proview PL926WBi 19" LCD Monitor
Plug and play PL716s proview monitor
after almost two/ three years my monitor is starting to give me trouble its comes on then it blinks off I have to constantly turn the power button on and off I cannot keep it on. Please help.
Jun 19, 2008 | Envision EN-7220 17" Flat Panel LCD...
Flashing Monitor
Sounds like either  a loose connection or a short in the cable going from the monitor to your computer.  Try disconnecting the monitor from the computer, and plugging it back in again.  If this doesn't resolve the issue, try bending the cable in different places.  If this causes the monitor to correct itself, even just for a little bit, it is a bad cable.  You can take it off from the monitor and the computer, take it to a store that sells cables, and get a new one.
May 29, 2008 | Proview PL926WBi 19" LCD Monitor
Proview monitor PL716s
you ave some blown caps on the vga board replace them and all will be well
Dec 28, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PL716s computer monitor
Bad Inverter. Or a surface mount component on the inverter. Either way it needs to be trouble shot down to the component level or replace the inverter board.
Sep 17, 2007 | Gateway FPD2275W LCD Monitor
Proview pl716s monitor will not come on
i just had this problem with my screen (proview pl716s) if you open the case and take out the power board, there are 6 470 uf capasitors bundled together and 1 220uf capasitor replace all 7 and that should fix your problem , that is what i did and it worked like a charm , oh and btw make sure before you swap your monitor from an older standard monitor to the lcd make sure the resolution is high enough becuase if it is not then the monitor will not be able to be displayd , hope that helps
Aug 16, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Open Questions:
See all Proview PL713S 17" Flat Panel LCD Monitor Questions
Proview PL713S 17" Flat Panel LCD Monitor Logo
109 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
