SOURCE: Ghosts in Tv Projection TV
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: double vision and no convergence
I have found that fusible link FL231 is the main cause of this problem. It's located by the high voltage transformer and looks like a square coil.
Check it with an ohm meter and if it checks bad, then, replace it and you should not have to realign the convergence.
Any questions or comments, respond to this post and I will reply.
SOURCE: Hitachi 46f500 convergence problem
Most likely the 2 convergence IC or one of them are shot if yes you need to repalce both.
If you have no electronics backgorund my advise is get a tech to replaced it for you.
Good luck.
SOURCE: red color distortion hitachi 46f500
Can't remember which this one uses but its right on the chips. Check your resistors too.
