I am renting a house in NC which has a Trane heat pump XL 1200, Model# TWX72AA100A1, Mfg. Date of 01/88; and a fairly new Honeywell digital thermostat.
During the cooling season the unit ran fine. Now that it has been switched to standard heat mode, the unit runs continuously for hours even after room temperature has been reached. It then brings the temperature down and it heats again like it is in a loop and the unit never gets a signal to turn off. It then has to be shut off manually at the thermostat by lowering the set temperature. However, it works just fine in emergency heat mode and shuts off when set temperature has been reached.
Would that problem indicate a faulty thermostat calibration or a potential problem with the unit itself? The unit is now almost 22 years old, but it has had new parts installed in the past few years. Thanks.
its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for...
(More)
its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for about 10 seconds then shuts off again. while it is running the control panel flashes FP, what is it trying to tell me? the reason the unit is off is because it only blows cold air on the heat side, whats wrong with it.
My 4yr old Amana heat pump quit working - the thermostat display was blank. I replaced the...
(More)
My 4yr old Amana heat pump quit working - the thermostat display was blank. I replaced the thermostat but still no luck after confirming it was installed correctly. My S/N is 0407477962, Model VNC60C2A, P/N247407C. I was told it was a 12 Seer unit; unfortunately I can't find my manual or find it listed on your website. Any assistance would be greatly appreciated.
Is there such thing like a kit to convert amana ptac wall unit to work on my existing hard wire wall...
(More)
Is there such thing like a kit to convert amana ptac wall unit to work on my existing hard wire wall thermostat?
