Probably you dont have the constant pos (+) wire hooked up to hot (+) wire and only to a source that is switched. Switched means every time your key is removed from ignition switch the positive current from that source will also power down. There are two positive leads from the unit, 1 always hot and the other needs to be switchable. The constant hot (usually yellow) powers the memory for your settings. Just like your television set, once you pull the cord off the socket everything returns to default setting.
need to install my CDA-9857 in 08 Ford explorer. I was told that I will need and expensive wirung...
(More)
need to install my CDA-9857 in 08 Ford explorer. I was told that I will need and expensive wirung harness an antenna adapter a module so I can still use my steering wheel controls and adapters for my serius sat reciever. In all the cost comes to 263.00. Does this sound right?
when i turn up my sterio at home my speakers keep cutting out i blew the speakers which come with...
(More)
when i turn up my sterio at home my speakers keep cutting out i blew the speakers which come with the unit so i replaced them with better ones but when i turn it up so loud they keep cutting out
i got the wire to use an mp3 player and i hooked it up and the mp3player isnt playing on my alpine...
(More)
I GOT THE WIRE TO USE AN MP3 PLAYER AND I HOOKED IT UP AND THE MP3PLAYER ISNT PLAYING ON MY ALPINE 9857 WHAT DO I DO
