Question about Philips Magnavox 51MP392H Rear Projection Television
Philips 60PP9363H/17 I would like to find a convergence for the tv above. Do you have any ideas on where I could pick one up that would be fairly inexpensive?
  • ttiger Dec 30, 2007
    picture is fussy and the colors at the bottom are seperating (blue and red)
  • Philips Master
  • 8,617 Answers
Electronix.com has what you need they are called convergence IC's. About 6 bucks each. Type in your model number and the correct parts will be displayed its an easy fix for someone who can solder. You need two IC'c both stk part numbers. Takes about 2 hours to desolder the old and replace with new, then it basic adjustment for convergence
Posted on Jan 03, 2008
  • 579 Answers
Do you want a convergence board? I think it is the SSA module. You can get a new one from partstore.com or I have a used module from a scrap unit.
Posted on Jan 02, 2008
2 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: Philips 60PP9363H/17
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Posted on Jan 30, 2009
Convergence bad on my 60pp9363h what part do i need to order
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 01, 2011 | Philips 60PP9363 60" Rear Projection...
How do you get to the convergance menu on phillips 60pp9363h/17 tv
Here are two tips from www.TvRepairKits.com
"You must have the original remote. If so you can access the convergence screen by hitting the menu key"
Jun 04, 2009 | Philips 46PP9302 46" Rear Projection...
SOUND BUT NO PICTURE
is it nothing on the screen at all? if so your projector bulb blew. they usually cost a coupole hundred bucks
Mar 07, 2009 | Philips 60PP9363 60" Rear Projection...
Phillips 60PP9363H/17 Picure warped and collor drifting
You have a convergence chip problem. You need to get a kit from www.TvRepairKits.com.
Note: The longer you run your set with a convergence problem the more problems you will have. Turn it off and get it fixed.
Nov 14, 2008 | Philips 60PP9363 60" Rear Projection...
Philips 60pp9363h/17
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Ed
Sep 09, 2008 | Philips 46PP9302 46" Rear Projection...
Phillips hd projection tv/ model 60pp9363h/17
thats a common problem with all projection tvs. You will need to replace both convergence Ics and 4 resistors. You will need two STK392-120 Convergence ICs and four 6.8 ohm 1watt resistors. You can get replacement parts at the following link and they provide free instalation instructions so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Philips 46PP9302 46" Rear Projection...
Picture is warping and colors are seperating giving a picture that looks like a 3D picture without the glasses
you need to replace both convergence Ics. Post the model number of your set and I will post the correct IC numbers as well as alink where you can get replacements with free instalation instructions. Respond to this same post so I will have access to your symptoms when you post the nodel number.
Jun 30, 2008 | Philips 46PP9302 46" Rear Projection...
My 60pp9363h/17 turned ff wont turn back on
If your Philips Magnavox Projection TV has the following symptoms....
Video screen shrinks and expands.
Or
No Video or Audio - But the power light comes on!
If you have either of the two problems listed above its likely that the opto isolator IC has failed.
You can get repair instructions and parts from the following site.
http:///www.magnavoxhelp.com
Jun 21, 2008 | Philips Televison & Video
Screen looks 3D
Solution:
Jan 11, 2008 | Philips 60PP9363 60" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
156 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
