Question about Cyberhome DVR 1600 DVD Recorder
After Recording and Closing The Title, I get a "No Disk" error message...
Then, if I eject and re-insert the disk, It spins with a little grinding noise and gives me another error message of "Unknown Disk". To this point, I have only tried recording from my saved DVR titles. I'm going to try to record direct from live TV after I submit this entry, and we'll see what happens. I've already burned through at least half a dozen DVD+R disks trying to get this to work. Please help before I throw this DVD Recorder out the window in frustration!!! Thanks in advance
My DVR started making noises and was very slow to start up, it was caused by the rubber ring in the center that grips the disk being dusty. I cleaned with long q-tip and alcohol to fix it. I had to take my Panasonic DVR apart. I can't find a cleaning disk that addresses this slipping problem.
Posted on Jul 14, 2008
I had this problem frequently over the last year, the one thing I did notice was that if the DVD's I attempted to use were very lightweight or thin, it would not format them. If you can find any of the older, thicker DVDs to record on, it may help. By the way, the ones I had that worked best were DVD+RW purchased at $1.99 for six. They had a heavy orange enamel on the tops. Withstood daily use for nearly a year. Still have some, even though the player needs medical attention now.
Posted on Jan 12, 2008
Error reading any dvd disks
Have you tried a DVD+/-RW ?
The noises that you are hearing will be the spindle motor trying to spin the DVD as the lifting presentation tray for the read/write head has not located, if the media is not spinning this will never be able to read the lead in on any DVD as it has not presented the disc in the correct place.
If is is out of guarantee then I suggest that you check to see if the DVD is spinning by removing the top cover with the power OFF then eject the tray and try to load the media a small touch of the DVD in the clockwise motion should cause the media to start spinning, this is for diagnosis only if this is the case then the spindle motor will need changing
May 28, 2010 | Panasonic DMRES15 DVD Recorder
Have the Samsung DVD-AR650. When I insert a blank
My last recommendation, before seeking a replace or repair; would be to run a cleaner disk. Optical drives can be affected by dust on the optical block lens or dust on the disk itself. Sometimes a dirty lens can even cause your drive to eject the disk when you try to read it. It is recommended you clean your lens every 3 months in an office environment, or once a month if you use the drive in an industrial environment. They range in price from $3 to as high as $130. In such an
Jan 01, 2010 | Samsung DVD-AR650
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Cannot Eject DVD
There will be a manual eject but its slightly tricky. There will be a small hole(about 1mm diameter) near the tray where you insert the DVD. Just insert a samll pin or something into it and keep shoving it in and out by repeatedly pressing the eject button. If its just a stuck DVD then it will come out in a JIFFy. Otherwise send it for repairs as taking the unit apart might void your warranty! Good luck!
Sai.
Jun 16, 2008 | Panasonic HDC-DX1 DVD Camcorder
Problem with reading and playing dvds
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 07, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Hung up - disk won't eject
cd recorder disk will not eject
Dec 08, 2007 | Panasonic VDR-M70 DVD Camcorder
Problem dubbing from VHS to DVD
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
Aug 23, 2007 | Sony RDR-VX555
Cyberhome DVR 1600 DVD Recorder Logo
170 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
