Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Turn it on and sometimes
By walkeratwork on Oct 20, 2009
Turn it on and sometimes it turns itself off. Can usually get it to stay on. When the set is warm the volume reduces by itself with lots of clicking noises, when it gets to zero the set changes channel by itself with more clicking noises. Cannot rectify without waiting for the TV to cool down.
Solution #1
posted on Oct 20, 2009
Somewhat Helpful)
charlymonty
Rank: Wiz  Televisions & Videos  Expert
Rating: 82%, 252 votes
tv turning off automatically
for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off.in this case the circuit board needs to be checked with a multimeter.the faulty and burned out component part should be detected and then should be replaced with the help of soldering iron.to make it proper.to avoid further damage i suggest you that do not on the tv again and again as it will short some more tiny components and the reparing cost will increase as per that.at present its the normal circuit short problem in the tv get it repaired before using the tv again.
youcan get the required parts from ------ www.partstore.com --
www.radioshack.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS... (More)
Answer
switched on my flat screen tv model no 40wlu530hid i could smell burning then the screen went blank.... (More)
Answer
turn on the tv,green light comes on and instantly goes off - this happened after i lost my... (More)
Answer
I fixed the flashing green light of death,tv worked fine for about a month. Now when I turn on tv I... (More)
Answer
when we put power ON , there is no screen display at all< no sound , in fact nothing happen... (More)
Describe your Projection Televisions problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
