Question about Yamaha RX-V2700 Receiver
Hdmi connections HI, THE PROBLEM WITH THIS RECEIVER IS AT THE HDMI CONNECTIONS, THE ONLY ONE THAT IS NOT GIVING ANY PROBLEMS IS THE CAB/SAT INPUT. THE DVD AND DTV INPUTS CUT OFF THE VIDEO SIGNAL AT TIMES, I HAVE TRIED DIFFERENT CABLES AND THE PROBLEM REMAINS. THANKS
  • 1 more comment
  • herrmann1 May 26, 2008
    The receiver will play back over two of the HDMI inputs for 20-30 minutes, and then starts cutting in and out every 2-3 seconds. HDMI input 3 doesn't work at all
  • SteveBriscoe Dec 27, 2008
    I have the same problem only my CAB/SAT HDMI works correctly seems to start after the unit heats up.
  • Sirrom01 Apr 26, 2009
    HDMI Monitor output to projector does not happen when it is the only output source. When I remove the S-Video output from the amp I get intermittent sound output every 2-3 seconds but no video output. Have swapped cables and sources and also tried altering the manual setup to try differing configerations
Hi, If you are trying to use HDMI video, and want to give autdio input separately, that can be done in many ways. In fact I am giving HDMI video from my HTPC at DTV inoput and audio over SPDIF (optical). In the menu there is an inout select option. You need to go into DTV, then select which audio to use. You can then choose whoch input port for audio is being used with DTV.
I have issues with HDMI input as well, but those have to do with refresh rate of 60 Hz and 1080i.
Posted on Jan 02, 2008
How to hook up a denon avr -1706 receiver To a lg smart tv
If you are tuning in TV stations with the TV set, you will need either an optical or a coaxial audio cable to go from the digital audio out of the TV to a digital audio in on the receiver. This setup should give you 5.1 Dolby digital sound. You can also use a pair of red and white rca cables, but you will only have 2 channel sound. You may need to set the TV to output the audio to external speakers. You will need to set the receiver to the input the TV audio is connected to.
If you want to watch Sat or Cable, you probably need a couple of HDMI cables. One HDMI cable will go from the output of the Sat/Cable box to the appropriate HDMI input on the receiver. The second HDMI cable will go from the Monitor Out on the receiver to an HDMI Input on the TV. You may need to set the receiver to output HDMI audio from the receiver, and not the TV. You will need to set the TV to the HDMI Input you connected to on the TV. You will also need to set the receiver to the input the Sat/Cable box is connected to.
Details of both of these setups should be covered in the receiver and the TV manuals. Refer to them for the detailed connections and settings you need to make.
Good Luck!
Mar 02, 2015 | Denon Audio Players & Recorders
How to run tv from sat box and not have to turn on the reicer all the time. When I do want surround use the digital audio off sat box. Yamaha RX V377
If your SAT Box has multiple outputs, hook the HDMI output to your receiver so you can get full surround on movies etc. Connect the HDMI out on your receiver to an HDMI input on the TV. Run a composite or S-video connection from the sat box to the TV for regular TV viewing/listening without the receiver & speakers. I don't think you can get full HD over either of these cables, but you may be able to use the composite connections if they are available on your sat box and TV.
Jan 16, 2015 | Yamaha RX-V377 Receiver 5.1 Channels, 70...
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
So i have this receiver and i have xbox, playstation and sat connected to it all threw hdmi in's but i have the hdmi output going to a projector and have no sound but picture it is driving me crazy plz...
hi,
do the following
1.press the input selector button on ur receiver to select the sat.
2.press the input mode button repeatedly on the receiver to select audio input mode
3 select it as AUTO.
do the same for the play station also.
ok
Jan 09, 2011 | Sony STR-DG820 Receiver
How to connect the herman kardon AVR 260
I have a AVR 247 and a AVR 347 there is a HDMI output on the back this will go direct to your HD TV HDMI input. If you have a HDMI output on your SAT. box then run this to the receiver HDMI 1 input. If you dont have a HDMI output on your SAT. box, then you want to use the digital fiber optic output from your SAT box and run it to OPT 1 input on the back of the receiver. This will be for audio only from the TV but thats all you want anyways. Be sure to set your receiver to HDMI 1 OPT 1 for this option. PS. This is a very clean and nice sounding receiver the only flaw to these receivers are the amount of heat they generate even on very low volumes. You must get a 4 or 5 inch boxer 120 volt fan and set on top of receiver blowing down and plug it in the back of receiver on the switched plug outlet so it comes on when powered up. This will make your receiver last 10 times longer. i have had mine for 3 years now and run them very hard sometimes with no problems with this fan addition. Hope this helps good luck.
May 24, 2010 | Harman Kardon AVR 2600
No video/display on TV when using sony str dh 500
If your set up is HDR-AVR and TV all you need to do is go HDMI out from HDR to HDMI in(Sat.) of AVR and monitor out HDMI (or composite video) to TV. and select the Sat. input on the AVR. The sound is only comming from the HDR in this case and the composite video or HD video is being switched out to the TV when you select Sat. on your AVR
Sep 20, 2009 | Sony STR-DH500 A/V Receiver
HDMI video not functioning on a new Onkyo TX-SR606
For me, it was the Monitor Out setting that had defaulted back to Component. I remembered to change the individual inputs to HDMI - but had forgotten to set the Monitor Out to be HDMI.
Nov 28, 2008 | Onkyo TX-SR606 Receiver
Yamaha RX-V2700 Receiver Logo
357 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
