Home | RCA | F31317 31" TV | I have a rca tv mod...
RCA F31317 31" TV
Problem for RCA F31317 31" TV
I have a rca tv model #F31317 it's less then 5 yrs
By j121262 on Oct 20, 2009
i have a rca tv model #F31317 it's less then 5 yrs old. i went to turn it on this morning, and i pushed the power button, and i heard the click, like it's gonna turn on, but it didn't no sound either, then i heard 3 more clicks after that. every time i tried it would do the same thing, even using the remote. i checked the breaker outside, it was fine, i checked the plugs, switched them, still nothing. i just would like to know if i need to buy another one, or it's something simple. if simple what part do i need to replace.i appreciate you taking the time to answer my questions.
thanks
Best Solution
posted on Oct 20, 2009
Very Helpful)
rusty_etech
Rank: Guru  RCA Televisions & Videos  Expert
Rating: 92%, 113 votes
Most likely you have a bad highvoltage transformer and possibly a shorted horizontal output transistor. The transistor can be checked with a volt/ohm meter. Check collector to base. It should be over 1000 ohms. The transformer can be tested for inductance with an inductance meter or "ringer". One or both of these can cause the problem you described.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for RCA F31317 31" TV
Questions and Unsolved Problems for RCA F31317 31" TV
Do you recommend RCA F31317 31" TV?
Answer
Answer
My RCA Model F31317 has intermittent picture display. The sound works but the picture will cut out... (More)
Answer
my sat went out and during the reset process I lost picture. just snowy static screen. still plays... (More)
Answer
my tv will not recinize when a cable box is hooked up to it. it keeps asking for a G-link for the... (More)
Answer
picture on my rca f31317 seems darker than normal, have adjusted to the brightest setting. any... (More)
Answer
changes channel down on it own nonstop
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA F31317 31" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
