Question about RCA P52937 52" Rear Projection Television
Sound I have great sound from DVD and VCR but just get buzzing from satellite. I have checked connections, replaced cable and switched out and checked satellite box... nothing. Any suggestions??
  • 4,402 Answers
Try this When the unit is unplugged and replugged, it empties these registers of the corrupt data.
fix is to place a 1mfd capacitor to ground on U13101 pin (15). This
swamps the closed caption data to the micro and stops the reception of
the defective data packet. In the event that later on the resolve the
defective data problem the capacitor can be removed. the close
caption feature will not work with this cap. installed
Posted on Jan 30, 2008
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
? 9:23
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help -
Dec 30, 2015 | Magnavox Televison & Video
No sound when I play back a commercial DVD
May be something wrong with HDMi cable.
Is there sound when play VCR?
Please test - check with regular RCA cable AV out.
If OK. Next step Replace HDMI cable.
IF No sound with RCA cable look like need replace VCR Main Board.
Feb 20, 2015 | Panasonic DMR-EZ485VK DVD Recorder/VCR
My vizio flatscreen lcd has pic but will not play sound through the tv output, however it will pay sound when watching a dvd - just not when watching satellite
Use the cables connecting the DVD and connect the satelite.
If everything works OK, then check and replace the cables for the Satellite.
If the sound is still No Good, check the audio settings on the satellite
You may connect the DVD using the Satellite cables as a check as well
Jun 05, 2009 | Televison & Video
No picture or sound magnavox mwd200g dvd player
on the side of the tv mostly there is a button for dvd mode you will have to press that button to reach in dvd mode.if no such button then its the cables fault or the wires are not connected properly just check out this link for connections
For tv/dvd /vcr connections
For tv/dvd /vcr question answers.
Mar 02, 2009 | Philips Magnavox MWD200G DVD Player
Pioneer vsx-d850s Home theater help needed
well i dont know how much they differ but i have a vsx-517 reciever(pioneer) all i do is run the one video out to my tv and run everthing else through my configuration is i have the tv/sat input hooked up to my dvd which has an video out and then my sat was hooked to dvr/vcr input hope this helps alo there is loudness setting and speaker configuratino as well i have my effect turned as far as they will go so i suppose it punches out fairly decednt volume at -60 through 35 any further and i sometimes overload my system lol anyway hope this helps if you need and idea on what it look like ill take a pic ans send it to you-z
Feb 18, 2009 | Audio Players & Recorders
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Magnavox dv225mg9 dvd/vcr player. Hooked it up to TV/Cable receiver/combo and I get great dvd reception sound and picture, but on the vcr I get only sound
I had the same issue. You probably have your unit connected with the newer cables that are red, blue and green. These are more sophisticated and offer better quality for the DVD portion. However, they will not carry the video for the VCR, only the audio.
You need to connect a *yellow* Video Out cable from your DVD/VCR to the Video In on your TV, this should carry the video for the VCR! Hope this helps!
Sep 30, 2008 | GoVideo Go Video DVD/VCR Combo
Toshiba VCR/DVD Recorder Combo - Problems connecting it to system
I was able to connect to my cable box. I used RCA (yellow, red, white) cabling. I connected the Video Out on the cable box to the Video In on the DVD/VC (to the DVD VCR cabling section). I then from same section used the Video Out using RCA Cabling to the the Video In connectors on my Phillips LCD TV. That left only to connect the TV to the cable box using regular TV coax cable. Everything works, although I am going nuts trying to dub from VCR to DVD-R or +R discs.
May 21, 2008 | Televison & Video
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): Hope that helps.
Aug 30, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Loud buzzing noise
Out put Capacitor breaking down - needs a serive replacement if available.
Nov 13, 2006 | Sony DVP-NS55P DVD Player
RCA P52937 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
