Fuel mix I have a Jonsereds chainsaw model 49SP serial# 1324394. What is the correct gas/oil mixture.
2 Suggested Answers
  • 15935 Answers
SOURCE: fuel mixture for antiqur Maytag engine
30:1 would be better.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
  • 8 Answers
That motor needs a 16/1 fuel-oil mix using two stroke oil designed for air cooled motors like chainsaws. Outboard oil is different and shouldn't be used!
Posted on Feb 03, 2016
0 characters
1 Points
Stihl chainsaw stalls after warm up
sounds like fuel line cloged or the someone played around
fuel mixture screw normaly if the screw has been turned
3 half turns out is a good place to start out from
Nov 01, 2012 | Washing Machines
Water wont shut off on our 700 LD model top load machine. Any advice appreciated.
this could be a stuck open mixer valve. remove the two water hoses on the back of the machine ( they connect to the plastic mix valve ) -- loosen the back panel of the machine,, the valve is held in place by one small screw ,, label wires ' hot and cold ' -- remove the valve and take it down to your local appliance repair shop and buy a new one and install and all should be 100% back to normal. ( make sure you get the make,model and serial number when you go down to the repair shop to make sure you get the correct part ).
if you need more help with this problem - please feel free to write me back here and I will walk you through any issues.
Feb 02, 2011 | Hoover Washing Machines
Which oil do you use for the ake 40 bosch chainsaw
You might miss someone answering your query as it is posted on the washing machine list!
I would re-post on the garden area.
Also state which oil you require- for the chain itself or to mix for a 2 stroke engine.
(actually for my Husqvana I use any of the 'normal' 2 stroke oils and any chain oil- very thick stuff!).
John C
Jan 30, 2011 | Washing Machines
Dear Sir/Madam, My problem is that although water is in the line and all hoses are hooked up, water is not being fed into the machine when it is turned on. Any suggestions
The water inlet/mixing valve is most probably clogged or not working. Turn off the water supply and remove the fill hoses from the water inlet/mixing valve and check the screens, if there's any. Lime scales might accumulate in the screens and prevent water from coming in.
Check the resistance of the valves using an ohmmeter. Set the ohmmeter to X1 and measure the resistance between the terminals of the valve solenoids. Replace the valve assembly if one of the valve solenoids reads open.
Specify the brand, model number, and serial number of the washer for specific and detailed troubleshooting and repair assistance.
Mar 03, 2010 | Washing Machines
Kenmore Series 80 Washer leaking oil underneath
Aug 21, 2009 | Kenmore 22642 Top Load Washer
Fuel mixture for antiqur Maytag engine
May 03, 2009 | Washing Machines
Cannot start. The pullcord will not move
If it wont pull you probably have ceased the piston in some way. You can get access to the piston by removing the exhaust baffle. Or disassembling the entire saw.
Try putting a screw driver in where the exhaust and trying to move the piston just a little bit, back and forth. Once thats done, use a heavier gas / oil mixture.
Apr 28, 2009 | LG WM-1832C Front Load Washer
I am unable to start the gas honda engine on my pressure washer.
Three things are needed to make your engine run. 1) Fuel. Make sure you have fuel in the tank. You can also check flow through the fuel filter. 2) Oxygen. The carb (choke) should be working. I've never seen one fail in a Honda machine. and 3) Ignition (spark). Some models have a low oil shutoff which shorts out the magneto if the oil level gets too low. Also, check the spark plug. If it's questionable, replace it. You can take out the plug, hold it to the engine case with the lead attached, pull the pullcord, and should see a spark jump at the end of the plug. If it does not then you can rule out the fuel & air for now. The plug should also be wet from fuel. If it is not then you can rule out 2 and 3 for now.
Apr 30, 2008 | Washing Machines
Karcher pressure washer motor surging,then motor cuts out
You didn't say if this is a gas or electric machine. I will give suggestions for a gas model. These small engines have air and fuel filters. check both, as it sounds like its getting bad air/fuel mixture. Also try a new spark plug. If this is electric let me know, I'll new some more info.
Mar 15, 2008 | Washing Machines
Awful smell in drum of washing machine
My friend told me of someone who researched this problem, and it is because we are using liquid detergent. Switch to a granular high efficiency detergent. Before you start using it, you must run through a mixture of about one cup Clorox and two cups vinegar through the washer, using the Sanitary setting. I am actually on-line now trying to research the exact proportions of Clorox and vinegar when I ran across your problem.
Nov 03, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
