Question about Dell Dimension 4600 PC Desktop
Motherboard I have been having a problem with my 4600. On startup, my disk drive leds are flashing amber and green, my monitor is black, and there is no power going to the keyboard, or so it appears seeing how the led light does not come on on num lock or caps lock. I have contacted dell support and the gentleman I spoke to narrowed the problem down to be either the POWERSOURCE or MOTHERBOARD. He then informed me the only way to differentiate between the two would be to purchase a new powersupply from dell spare parts dept and if that does not make a difference I should go ahead and purchase a new motherboard. My problem now is, I don't know what the motherboard looks like or how to remove it my self to replace it. Same goes for the power supply. I am trying to keep the cost down by doing this myself. Can you help me out?
  • rne783 Jan 01, 2008
    I appreciate your advice and suggestions, but I am afraid I don't know that much about chiplevel servicing or even what the motherboard looks likes. Is there another way to explain this to me?
    Thanks so much :D
  • 3 Answers
Ya definetely....i will help u out in solving the problem.
first of all open the side cover of the cabinet.....here i am first instructing you how to check the power supply in the system..
as soon as you open the side cover of the cabinet the remove all the wires coming to the motherboard from the powersupply.then there u can see a 20 pin connector coming to the motherboard from the powersupply.in that bunch of 20 wires shot the green colour wire and the black colour wire...and give the power to the powersupply. if its ok and the fan of the powersupply is working then the smps is ok other wise u need to get it repaired by giving it for chiplevel servicing.....
if powersupply is ok then check whether there are any burns on motherboard if so and even if not u need to give the motherboard for chiplevel servicing.....
Posted on Dec 29, 2007
My screen is going black when I turn it on.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 23, 2011 | Computers & Internet
Amber light flashing on switching on the pc why?
HI,
A blinking amber light means that there is a problem with the power supply or the motherboard. I know that could be a number of things. Perhaps you could give some additional information.
1) Does the green light come on on the motherboard?
2) Do any/all of the fans work? Power supply or computer cooling.
3) Do you get any other lights? CD/DVD player?
You may have to get someone to see if your power supply outputs are all good.
I hope that gives you some starting points.
Thanks for using Fixya.
Nov 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
two things
  1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
  2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
Feb 13, 2010 | Computers & Internet
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
No monitor, black with "video cable connected?"
if you have swapped all other devices then yes it is probably MB, and yes there are ways to test it but i would just swap out the MB and see if it works.
Jun 22, 2009 | Computers & Internet
Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Hp L1502 LCD blank, LED still flashes
just check ur lcd display cable and try to clean and c it it will cme
May 29, 2009 | Samsung SyncMaster 910T 19" LCD Monitor
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Dell wont start up
On the back of the chassis, there are 4 LEDs above the PS2 connections marked ABCD what do they indicate? During the boot process the lights normally flash on and off green, when the boot process is complete, they should all be green GGGG.
If any are Amber then they are indicating a power on self test (POST) failure. AAGG is bad memory for example.
Post the indications
Aug 06, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
93 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
