Home | Dell | OptiPlex GX620 PC Desktop | I have a dell opt...
Dell OptiPlex GX620 PC Desktop
Problem for Dell OptiPlex GX620 PC Desktop
I have a dell optiplex gx620 and it wont turn on
By mooreleader on Oct 20, 2009
i have a dell optiplex gx620 and it wont turn on all it does is the power button flashes orange.
Best Solution
posted on Oct 20, 2009
Very Helpful)
bschilz
Rank: Guru  Dell Computer Hardware  Expert
Rating: 88%, 569 votes
As you can imagine, this is not simple thing to diagnose.
First, we need to try Dell's steps to fix...
Remove non-essential peripherals…
Except for the monitor, keyboard, and mouse, remove all external peripherals including:
  • Scanner
  • Printer
  • Modem or Network cables
  • Personal Digital Assistant (PDA)
  • USB flash drive or other external Hard Drive
  • Any other external devices (e.g., USB-attached devices)
  • Remove the computer from the docking station, if you are using one
  • Scanner
  • Printer
Try rebooting. If that doesn’t work, Dell states you need to do the next step.
Remove and Reseat Basic Hardware items:
  1. Power Cord
  2. Memory
  3. Hard Drive
At this point, Dells says if that fails contact them.
If my hunch is correct, you may have something on the motherboard shorting a connection or you have a blown capacitor. Get some “canned air” and blow out the computer thoroughly. Some people have reported the same symptom having dust or other debris causing the issue, so give it a good blowing out,
At the same time, inspect your motherboard thoroughly for an anomalies. If you see anything resembling the picture below, you have a serious motherboard problem which will require replacement.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
Azum
Rank: Guru  Computer Hardware  Expert
Rating: 86%, 284 votes
Sir,
It seems that you computers power supply has got damaged or burned you will be required to replace your power supply it would be better if you buy the 400 to 500 W power supply.
Was this helpful?
Yes
No
Solution #3
posted on Nov 11, 2009
Not Rated)
rain_catcher
Rank: Wiz  Computer Hardware  Expert
Rating: 77%, 51 votes
ok if the ups is not the problem you can try looking in the back of your pc you will see a little orange or red swith that can be clicked side to side or up and down. this is your US and over seas power seting. if its on 115 try clicking to 220/230
now try booting if it still does not boot return it back to 115 and pull the main power connector from the motherboard,.. wait 5 minutes to release and power the board may have. reconect power connector to motherboard and boot pc.
Was this helpful?
Yes
No
Solution #4
posted on Nov 02, 2009
Not Rated)
babycriminal
Rank: Apprentice  Computer Hardware  Expert
Rating: 0%, 0 votes
My eMachine T2542 keep blinking green. I thought it was a bad PSU but I tried a new one and that didn't fix the issue any answers to what's causing this problem?
Was this helpful?
Yes
No
Popular Solutions for Dell OptiPlex GX620 PC Desktop
Questions and Unsolved Problems for Dell OptiPlex GX620 PC Desktop
Do you recommend Dell OptiPlex GX620 PC Desktop?
Answer
Answer
I want to clean the inside of a sony v3s but I cant figure out how to get in. Can you help?
Answer
I cant get my Toshiba Equium to work off the mains. I have had it on charge over night to try and... (More)
Answer
how do you know if you get fcpga or fcpga 2 on the motherboard? it is socket 370 and fc pga 2 is... (More)
Answer
Cant find short cut for games on Pc Advisor
Answer
my computer just keeps clicking at the multi socket will not make a starting connection
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell OptiPlex GX620 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
