Question about Hotpoint Ultima WF860 Front Load Washer
Washing machine the machine starts cycle then display shows F-02
    Sniper:
  • 74 Answers
Http://www.reviewcentre.com/review180754.html
as you can read in this site is a comun problem with this model for all the codes the conclution of the company is by a new one I dont now how is that but any way is a big problem changing the board will solve the problem but how much will cost you is the mater....good luck and rate me
Posted on Jan 01, 2008
Wont start, goes straight to cycle ended
have the program board check for failure
Jan 04, 2016 | Electrolux Washing Machines
Won't finish the wash cycle and flashes the code F 02
This code means that the machine is not evacuating its water.
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jun 09, 2011 | Kenmore Washing Machines
Washer starts wash cycle and runs for about 5 mins then stops and displays F 02 on the clock
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Whirlpool GHW9300 Duet Washer
F02 keeps showing on display
If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
Cause: wrong detergent, too much of the right detergent, detergent placed in wrong compartment.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 18, 2010 | Whirlpool GHW9400 Duet Washer
Have error code of f 02 showing up on my duet. It is not finishing spin or drain cycle?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
02 f error code
F/02 code appears because :---------Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
to resolve this problem  :----------
  • If the above does not correct the problem, replace the pump.----------------
  • rate the solution.
thanks.
Jan 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine fault
lg trom showing E and on display won't drain
Mar 26, 2008 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
29 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
