GE DBXR463EBWW / DBXR463EBCC Electric Dryer
Problem for GE DBXR463EBWW / DBXR463EBCC Electric Dryer
Squeaking and clothes get caught in door
By prk5051 on Oct 20, 2009
Solution #1
posted on Oct 21, 2009
Not Rated)
hunter19_46m
Rank: Guru  GE Washers & Dryers  Expert
Rating: 91%, 338 votes
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers is in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum,belt, and front seal. Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
If your front seal is bad, it will cause clothes to be caught, replace it if it is needed, or reinstall if it has come out of place.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Was this helpful?
Yes
No
Popular Solutions for GE DBXR463EBWW / DBXR463EBCC
Questions and Unsolved Problems for GE DBXR463EBWW / DBXR463EBCC
Do you recommend GE DBXR463EBWW / DBXR463EBCC Electric Dryer?
Answer
Answer
Hoover tumble dryer cut out before time was up. When tried to restart just makes a noise, drum... (More)
Answer
When I turn the start bswitch to the start position the dryer starts. When I release the switch the... (More)
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , PA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
