TV Receivers and DVRs
Problem for TV Receivers and DVRs
Generic problem for all TV Receivers and DVRs
No dishnetwork signal
By lynji on Dec 29, 2007
Ok, here's the deal, we were watching TV one minute, and then the next the service went out and we received the message where the dish is trying to download. It says it is at "0 of 5 transponders", and nothing happens. It changes transponder numbers and tries to download, but that's about it. I have gone through all of the troubleshooting tips from dishnetwork to no avail. We have not had inclement weather, so there is no snow or rain or anything else on the dish. We've reset the receiver multiple times. We've pulled the smartcard and put it back in. We still have no service, and I can't get dishnetwork to send out a tech to look at it.
Comments:
Dec 30, 2007
- The satellite dish has only been hooked up at our current address for a little over a month, so all the parts are new. We've checked the cable, the connectors and the splitters. Nothing is corroded. We even replaced some of them, and still nothing. We get a message on the screen that shows it's trying to download the signal, but then it doesn't do anything. Any other suggestions?
Same Problem
Nov 19, 2008
-   We have the same problem but w/ our 322 receiver it will lose signal on one remote yet the other one will work but now we can't run both tvs at the same time and get a signal/picture. This system was installed by dish back in April so we'll do the check on the outside of the cables. Funny though at our other house we had dish and never had this issue but will report back my findings. Thanks for the fix....I'll keep you posted. Perhaps the quality of the cables used these days are so cheap the do have corrosion issues.-   justme10
Jun 08, 2008
-   We have the same problem.  It happened with one tv yesterday and now both tv's are down.  We are getting no signal strength. None.  Why would we not be getting any signal strength when it was just working a day ago?-   mnsailor
Solution #1
posted on Dec 30, 2007
Somewhat Helpful)
satscoop
Rank: Wiz
Rating: 84%, 125 votes
OK here we go .the most common problem with dish network and directv is that any cable connections you have that are on the outside of the house are a HUGE weak point in the system.what you want to do is go outside and locate the dish once you have start following the cables until you find any of these cable connections or splices.once you have located them get a 7/16 wrench and remove the cable ..What your are looking for is corrosion in the cable connection.it will look like rust.What happens is your dish system sends 13 and 18 volts down the line to switch channels.When any water gets in these connections it will start to short the connection BUT,you will still get TV for a long while eventually this small short will start to damage the cable connection and you will lose signal all together.make sure to check all of these OUTSIDE connections.Once you find one that is bad you can go to radioshack and buy a cable prep tool that STRIPS the coax"COAX STRIPPERS" to its correct lengths.simply cut off the old connector and replace it.There is a GREAT tutorial at satellitescoop.com that shows you how to do this the right way for under 10 dollars make sure to follow the directions on that site and you should be watching TV in no time.
Comments:
Dec 30, 2007
- Yes go to the menu and get to where you can view your signal strength meter.If you dont have a signal ,go out to your dish and see if it has a sturdy mount and that its tight if its not tight then it needs to be tightened down to the roof or wall unless you have a pole mount.then the pole may need to be deeper in the ground.once you are sure the dish is mounted and sturdy loosen the bolts and make sure someone is watching the signal meter and move the dish SLOWLY to the right or left and see if you can get a signal,keep communicating with that person, if you get a signal then peak the signal.If you have a really low signal that can cause the 1 of 5 searching signal.If that doesnt work leave more info like how many receivers you have and how many rooms and if your having the same problem on more than one TV this helps alot to narrow down the problem.If you have more than one receiver and the problem is with both of them then that tells you that the problem is with the dish alignment or the LNB or "eye" has failed.Please leave me as much info as you can about the system and I might be able to help you solve the problem.
Was this helpful?
Yes
No
Popular Solutions for TV Receivers and DVRs
Questions and Unsolved Problems for TV Receivers and DVRs
Answer
I need to buy a good quality TV receiver (on air telecasted TV channels) How does this product... (More)
Answer
how can I use my westell 327W modem as a wireless router? It came with a USB wireless card inside a... (More)
Answer
Bought an Acesonic DGX-210 and everything works except the video. When I put the CDG in it comes up... (More)
Answer
need the manufacterers installation code as wont let me go no further to update
Answer
I own an AVerTV Box 7 in which I used to watch TV both while my CPU was on and also when my CPU was... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Receivers... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
