Question about Williams 2509612 Ceramic Mid-Size Heater
Heats up and shuts off
Wall heater willams 3509622 heats up then shut down pilot too. i change the thermocouple all ready
  • jAVIER fERNANDEZ Jan 23, 2008
    The heater starts and, afeter a while, it shuts off all, including the pilot. It happens more and more often.
    The heater starts properly, but after a few minutes it shuts off, including the pilot. It happens more and more often.
    Sergeant:
  • 288 Answers
There are 2 things to check. First is the thermostat. Next is the thermal safety switch located up on the heat exchanger. by-pass these one at a time by connecting the wires together. If that solves the problem, change to a new one. If neither one of these items are bad, you need a new gas valve.
Posted on Dec 31, 2007
The pilot will not stay lit after water in tank reaches desired temperature. After tank cools down pilot will relight and heat water again thyen goes out approximately 1-2 minute3s after water has been...
Thermocouple is getting weak... the extra heat from the main burner will keep it lit but after it goes out the thermocouple will then shut down..
Replace the thermocouple...
heatman101
Apr 30, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
30,000 btu wall mount reddy heater nat. gas. pilot lights and heater will run for about a min. then i hear a click in the main control and everything shuts down. Is this the double safety i read about...
Yes your pilot light may not be surrounding the thermocouple. Check and see it the pilot is burning blue and surrounds the thermocouple . These units are very sensitive if even a little breeze across the unit. You can clean the pilot with compressed air or maybe even a small wire brush. If this doesn't work you may have to change the thermocouple.
Apr 21, 2011 | Heating & Cooling
Pilot light lights but when turnd on it does not get hot and shuts off in 1or2 minuts
This is normally caused by the thermocouple. This is the part the pilot light heats up to let the heater know the gas is on and the pilot light is lit. The heater will shut off if it thinks the pilot light is not lit for safety reasons. You will need to change the thermocouple for it to work again correctly.
Nov 12, 2009 | Dyna-Glo RMC-8001SS Heater
Pilot flame moves off thermocouple when main flame
You must get the dust out of the ODS chamber that builds up during warmer months. If you go monkeying with the flap it will quit altogether. I use a simple squirt of rustbuster into the pilot, let it dry and all is well once more. You can get rustbuster at ace hardware for $2
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 10, 2009 | Heating & Cooling
Unit shuts down after 1 or 2 min.
Yeah, I've got a solution. SHUT OFF YOUR GAS SUPPLY VALVE FIRST!!! If your pilot won't light or if it lights and kicks off soon then check the orifice. I've got a 30,000 BTU LP gas unit. when my pilot did light, the flame was not totally encompassing the thermocouple nipple which lies behind the sparker/igniter furthest away from the flame. It cause the thermocouple nipple to cool too much and shut off the unit. I took the unit off the wall. I undid the four screws on the back of the unit, which holds the glass front plate. Then I took apart the multi-sectioned brass piece that is attached to the gas feed line for the pilot with a 13 mm and a11mm open end wrench, or you can use a small adjustable and a set of pliers. The second brass piece, the 11mm one, from the gas feed line, is the orifice. It has a tiny little hole in the center. I stuck a pin in it and cleaned it out from some debris that had clogged it. You do not have to take off anything else but those two pieces going from the gas feed tube. I put it all back together and I'm back in business. Now if you do this and it still doesn't work, buy a new thermocouple. They're cheap. Somewhere between six and ten bucks last I looked, Honeywell makes them and they fit most gas units besides Glo-Warm. Have a nice Day. Cadge
Oct 10, 2009 | Desa International Blower Glow Warm Wall...
Wall furnace troubleshooting
A thermocouple is inexpensive.  Replace if in doubt.  Get a professional in to do safety checks.  You may also want that individual to replace the thermocouple.
Nov 26, 2008 | Heating & Cooling
Torpedo heater lights and runs with control kknob pressed in but shuts down when control knob is released.
Change the thermocouple. The thermocouple scenes the heat from the pilot lit and signals the main gas valve to remain in the ready condition. The main valve will not receive the signal if the thermocouple is bad and will revert to the safety shut down when the control knob is released.
Nov 20, 2008 | Dayton Heating & Cooling
Heater shutting off
this type of heater is very sensitive to the state of the pilot since it uses a Renni type thermocouple to sense a low oxygen situation. Usually the pilot needs to be cleaned. If that does not restore operation only other thing to do is try replacing the thermocouple.
A low pilot will usually hold for a few minutes so I would expect that you have a bad thermocouple.
Nov 17, 2008 | Desa International Blower Glow Warm Wall...
Williams 2509612 Ceramic Mid-Size Heater Logo
355 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
vance jones
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
