Question about Sony DAV-IS10 System
Remote code for DAV-IS10
Trying to set up a universal remote to work with the Sony DAV-IS10... What is the remote code? Everything I have tried from the universal remote code list doesn't seem to work.
  • 3 more comments
  • bananazzz Jan 06, 2008
    exactly the same problem here.
  • Anonymous Jan 13, 2008
    I have the same problem, no sony manufacturers code from comcast's manual seems to work.
  • Anonymous Apr 29, 2008
    I'm looking for the Remote code for a Vizio TV
  • Anonymous Dec 31, 2008
    again
  • Anonymous May 10, 2009
    I tried solution 2, got the RM-V210. Was able to get most stuff working under the sony codes (nonthing worked with the bose code). However, was not able access any set up screen with any of the codes.
Hey guys I was looking around as well ...I found a universal remote that actually worked A++++ .....the name is SONY multi brand remote commander RM-V210 the trick is try under the BOSE code it worked for me picked it up at Walmart for like $12 bucks..
Posted on Apr 01, 2009
5 in 1 for all universal remote from curry.Go to the AMP button for amplifier and use the codes on the manual for this you will find that this will work.
Posted on Apr 08, 2009
If u are using an HDMI cable, when u turn/shut tv the sony dav should respond the same synching with tv on/off response.
Posted on Apr 26, 2008
Hi all, I hope someone out there can help me. Recently bought a new Samsung 46" LCD, I also have a Samsung BluRay player and HD Recorder in one, also have a PS3 and finally the Sony DAV-IS10. ...
It's unclear where the sound is emanating or where it is lost in this scenario or even the type of connection you're using to carry it.
It almost sounds like you're using the TV for sound or it's in the audio path. The sound from any high end source should be processed by the SONY DAV as close to its original device as possible and not unnecessarily patched through the TV.
The TV only NEEDS Video. High-end Audio is wasted on it.
The symptom sounds suspiciously like a loss of data from the source to the Sony DAV.
Please clarify or establish that this does or does not happen without using the remote. Sometimes remote commands are heeded by unintended devices. Try to Pause/Play sequence using front panel buttons on the unidentified Samsung BluRay to eliminate that possibility.
http://www.retrevo.com/support/Sony-DAV-IS10-Home-Theater-Systems-manual/id/2771ag604/t/2/
Observe the indicators on the Sony for any clues when the problem occurs.
Sep 24, 2011 | Sony DAV-IS10 System
I have a Sony DAV-DZ120 HOme Theater system, i just got Dish Network Installed and cannot find the code for the dish network remote to run my system, just trying to use one remote for everything rather...
Sorry, your Sony remote doesn't support DishNetwork in any way. Either you will have to use 2 separate remotes or buy a programmable remote that supports all of them. One like
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6621
Sep 04, 2010 | Sony Dream Home Theater System, DAV-DZ120...
Cannot find code for universal remotes to make Sony DAV-C450 work
To repair your original remote, open the remote and remove the buttons sectio.(normally a solid piece of rubber with the buttons) On the PC board of the remote, clean with a scotchbrite scourer to revive the circuits and make it shiny. Next, clean the rubber button section on the inside with surgical spirits. Replace cover and fit new batteries.
Jul 12, 2010 | Sony DAV-C450 System
Need 5-digit code for universal remote on DAV-X1
There may be no code in the library of your Insight remote. You may have to try a different universal remote.
Apr 04, 2017 | Sony DAV-X1 System
Can I setup a sony dav is 10 with a universal remote
I cant find any that will work with your unit! www.remotes.com can send you an orignal one in almost all cases!
Please rate!
THANK YOU!
Jan 15, 2009 | Sony DAV-IS10 System
Can I set up a Sony DAV IS 10 using a universal remote
Look go to www.remotes.com and I am pretty sure you can order the orignal remote for youe unit with no problems! I cant find any universal that will run that unit at this time!
please take a second out and rate response!
THANK YOU!
Need code to program Comcast Universal Remote to our Sony DAV FR9
First you need a Comcast remote with the center button, OK/Select to be grey. Now program in code 1903 to aux. Works on my FR8 System, same basic as FR9. I was unable to get Comcast remote with red center, OK/Select, to work with any codes.
Dec 31, 2008 | Sony DAV-FR9 System
Sony DAV-IS10 System Logo
1,921 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
