Question about Hisense TL1700 17 in. LCD Television
HISENSE TL2020 My TV is Hisense TL 2020 20 in. LCD TV The channels of my TV change automatically. Also when the shut the TV off, it restarts automatically. Could you please let me know what the problem could be? If any particular IC needs to be changed, please let me know.
  • Anonymous May 01, 2008
    Yes, the have the same problem.
    How do I get it out of the DEMO mode?
    I dont have the manual anymore
    Thx in advance
Is it in demo mode
Posted on Dec 29, 2007
Hisense tl2020 sound doesn't come on
What we call a thermal problem----if a 17 inch likely not cost effective to repair and company who made it in China does not really sell parts.
Mar 18, 2012 | Hisense TL1700 17 in. LCD Television
I have a Hisense tl 2020 and last night when turned it on I had no sound
Try first leaving the unit unplugged from main for one hour.
This will drain power and reset circuits.
Check also eventual cable connections, receiver box or device connected.
If that does not solve the problem, then there is an internal fault, probably on audio circuits or I/O board.
May 21, 2009 | Televison & Video
Hisense tl2020 will not power on
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Aug 18, 2017 | Hisense TL1700 17 in. LCD Television
Hisense Remote Control won't work
In trying to program a universal remote for my Hi-Sense TV, the TV locked. How can I unlock it?
Oct 23, 2008 | Hisense TL1700 17 in. LCD Television
Hisense
your Tv remort Or Tv Swich service Requied
Sep 18, 2008 | Hisense LHD3204US 32 in. LCD HDTV
Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
Sep 16, 2008 | Hisense LCD1504 15 in. Television
INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Aug 04, 2008 | Hisense TL-3220 Television
My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Jun 03, 2008 | Hisense TL1700 17 in. LCD Television
Hisense TL2020 LCD TV
Try turning the main power switch on the back of the tv off.
Then hold the menu button and push that switch back on while still holding the menu button.
Keep holding the menu button until the setup menu pops up.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That did it for me. After I shut it off I had to do it one more time but it did the job. A friend of mine gave me the tv for free because nobody he new could figure it out. I took it home, got lucky, and figured it out in about ten minutes.
jb
May 23, 2008 | Hisense TL1700 17 in. LCD Television
Hisense TL2020 TV repairing
To unlock your Tl2020 with a universal remote just go into the menu and select V chip setting. The password from the factory is four zeros (0 0 0 0 ). Once you get in you will the letter "B" nect to everything. Set everything to the letter "U". Then, turn off the television. The set should be unlocked now. Good luck !
Frank
Sep 15, 2007 | Hisense TL1700 17 in. LCD Television
Hisense TL1700 17 in. LCD Television Logo
1,250 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
