Question about GPX MW3337G
One speaker doesn't work
I have had my player less than a month, and the left speaker stopped working. Regardless of which pjack you plug the headphones into, it doesn't work. It also doesn't work using other headphones or speakers. Is this a defect? Has anyone else had this problem?
  • Anonymous Sep 16, 2008
    I had the same problem with 2 different GPX MP3 players. Finally went to radioshack and got new headphones.
    Problem Solver:
  • 8 Answers
I did, but I realized that I hadn't pushed the plug all the way in, so...I don't know other than that.
Posted on Jul 24, 2008
Cannot connect Philips DVD Model 2850/12 player to he above tv
I see no TV but there should be either an HDMI pjack or RCA jacks to plug the player in with .
Oct 13, 2015 | Philips Televison & Video
Right monitor has stopped working, left still works
Electrical parts were bad, I returned the speakers for replacement under warranty. FYI... I opened the back and noticed an electrical burn smell.
May 06, 2014 | Alesis M1 Active 320 USB Speakers
The speakers that came with the computer stop working. 2 months
  • this is probably a connection problem so check the connections and if neccasary replace the cable connecting them with the computer.
  • also chechk to make sure its not muted internally (muted on the computer itself)
Oct 09, 2009 | Audio Players & Recorders
Wharfedale s20030 speakers broken?
First, check input power (electricity) of your speaker. You can see lamp indicator on speaker (usually LED lamp, Light Emitting Diode, green light or else) must be light ON.
Two, jack line out (usually green) on the speaker, you must touch that jack. Don't worry, you can't heart attack cause of it (for touching that jack, DC-Direct Current supply). If you hear some noise, sound of droning, buzzing, that is indicate of sound will be come out from that speaker.
Three, you play WinAmp software (or Windows Media Player, from Microsoft) and get in one of mp3 file, and load it into WinAmp player. Make sure if your mp3 file is normally sound.
Four, plug in your green jack (of speaker) to the line in of your sound card (refer to mainboard PC, if your soundcard get in ONBOARD or plug in PCI slot). Green jack line of speaker to socket green of sound card.
Five, now you can hear sound of your song....
Sep 06, 2009 | Computers & Internet
Left speaker suddenly stopped working correctly.
check the plugin going into the back of the computer. it might be loose and only sending the audio to the right channel. Otherwise, check the connections in the back of the speaker.
Jul 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
One speaker wont work
if u have experience with the soldering of the terminals then you can open the speaker casing of the sub woofer and then solder the right speaker input wire.
dont do this if you have no previous experience and DISCONNECT THE POWER SUPPLY before doing any work inside.
Apr 19, 2009 | Logitech Z-2300 2.1 Computer Speaker...
It isn't working!
plug in into the usb and while its plugged in press the reset button-worked for me-so far its happened twice to mine-shoulda just left it as it was and took it in for product replacement
Sep 04, 2008 | Creative Labs ZEN V Plus MP3 Player
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
One speaker has stopped working
It could be the cable connecting to the speaker, or the speaker itself. Try taking the cable that's connected to the left speaker and connecting it to the right speaker. If it works, the cable connected to your right speaker is defective, if it doesn't work - your speaker is.
Jan 10, 2008 | Toshiba 36A43 36" TV
Wires came out of the plug
From Pioneer Electronics Support Website Yellow - To terminal always supplied with power regardless of ignition switch position. Red - To electric terminal controlled by ignition switch (12 V DC) ON/OFF. Black (ground) - To vehicle (metal) body Blue/white - To system control terminal of the power amp or Auto-antenna relay control terminal White - front speaker left + (positive) White/black - front speaker left - (negative) Grey - front speaker right + (positive) Grey/Black - front speaker right - (negative) Green - rear speaker left + (positive) Green/Black - rear speaker left - (negative) Violet - rear speaker right + (positive) Violet/black - rear speaker right - (negative) Best of Luck.
Sep 09, 2007 | Pioneer DEH-P3800MP CD Player
GPX MW3337G Logo
135 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
