Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Green clean light dishwasher will not run
Tried to press heated dry and sani rinse all the lights came on now what
Unit hs had power disconected for four months
Posted on Dec 29, 2007
  • 196 Answers
First step is to disconnect the machine from power for 5-10 minutes. This will reset the computer. Depending on the age of the machine, there should be a start-up guide in the users manual. This guide may have the error codes. Try setting the unit to AUTO and see if the main functions are working.
Quiet partner whirlpool III gold reset
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
I have a KitchenAid KUDP02FR. Must be the same manufacturer because it has the...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Nov 06, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
I have a whirlpool adp951 with a green light flashing
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
thank you for using fixya,rate my answer,
Oct 02, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Flashing clean light and wont start. Is there a sequence of buttons to reset the switchboard?
sani rinse---heated dry---sani rinse---- heated dry.. all the lights on console should light then close the door, let run for 20 -30 secs, and cancel the cycle, if the problem happens again yo need t call a servicer. 1 time maybe a fluke but to happen again indicates a heating, issue somewhere(or a lack of heating)
Mar 04, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
This worked great - press Sani Dry, then press Heated Dry - then repeat - press Sani Dry, then press Heated Dry. All control lights will light and then press Cancel. The control panel should work normally.
Nov 05, 2008 | Kenmore 24 in. 17033 Built-in Dishwasher
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Green clean light flashing dishwasher
Nov 22, 2007 | Dishwashers
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
60 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
