Question about Fostex MR16HD/CD Digital Recorder
Locked up. Hard drive frozen?
Help! We were recording tracks just fine and when it went to store a track, the usual 2-3 seconds 'please wait' locked up. No controls worked, not even the power button.  I unplugged it after a few minutes hoping it would reset, but when powered back up I get nothing but 'please wait'.
Just bought the machine last week.
Hard drive fried? Any 'reset' option available? I still have no access to the menu or any controls.
  • Anonymous Feb 11, 2008
    Tried downloading usb update and for several minutes I had the "please wait" message. Half an hour went by and I decided to re-boot and when I did I got a hard drive error message. Had it a week, never been used. The hard drive is fried. This was with the MR8HD.
I have the same frickin problem.someone please help
Posted on Feb 11, 2008
Details I record drum/ bass and synth loops into logic and then send them to the rc50 loop pedal, i had 50 seconds of recording time left so i added a new track which left me 25 seconds of recording t
Likely the memory is fragmented into tiny snipets much like hard drives get. For looping, the memory likely has to be contiguous chunks. Clear the memory and load each in sequence.
Feb 23, 2013 | Audio Players & Recorders
I'm attempting to install a Hitachi hard disk drive model DK237A-32 removed from a Roland VS 1680 digital 16 track recorder into my PC which runs Windows vista OS. I've done a ton of research but...
The last time i used a VS-1680 was probably over 7 years ago, but if memory serves me right the only way of taking the tracks of to a pc, was by using an spdif line out to the pc and recording them that way, which if i remember right was a dog slow process as you were limited in how many tracks you could record at a time. there is an old forum i used to frequent with a guy quoting this
http://homerecording.com/bbs/user-forums-brand/roland-boss-vs-series-forum/roland-vs1680-pc-file-transfers-96373/#post906840
so that may be another way of doing it
Sorry i couldnt be any more help
Jun 27, 2011 | Hitachi (DK237A-32) 3.24 GB Hard Drive
I was using my recorder and it locked up. Nothing worked, I couldn't get any of the track arming buttons, transport buttons, the shutdown button, or the mute/solo buttons to work. the only thing that...
It sounds like the hard drive has failed... cheap test, get another and reformat the new one. They are so inexpensive now. To avoid losing data, they lock things up if anything goes wrong. The unit probably can't get the ready signal from the drive and freezes...
Apr 21, 2011 | Tascam 2488mkii 24 Track Recording...
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Recording guitar tracks on my computer are out of sync help
Most recording programs have a some way to keep tracks in sync. It is usually some type of begining and end marker. When you press record for the second track it starts the begining marker. What is the program your using?
Mar 14, 2009 | Dell Dimension 2400 PC Desktop
Locked on 'bad track'
have you ever set the auto shut off timer in the settings menu?? if you have, it will shut off in the amount of time set in there. if not, maybe you should try pluggin it into your computer and taking all the music off. the bad track thing has happened to me b4, but it has never frozen....that's pretty much anyhting i kno of that you could try.....sorry if this doesn't help =]
Aug 29, 2008 | SanDisk Sansa e250 MP3 Player
Is there any way to record Tascam 2488 Multieffects directly to the hard drive when I record? When I change tracks during playback, the previous effect that I used disappears...Please help???
Yes. Rather than pressing the track SELECT button to assign the effect, press one of the SOURCE buttons to the left of the EFFECTS. This will record the effect HARD to the track as oopposed to SOFT. SOFT being that the effect will NOT be recorded whereas HARD means it IS recorded and will be there anytime you play the track. NOTE: Just make sure that's the effect you want as it is then part of the track.
Aug 21, 2008 | Tascam 2488 Portastudio Multitrack...
DP-01FX
I shut down the system, waited 30 seconds, turned it back on, and the recording went fine. Must've been a glitch.
Jun 18, 2008 | Tascam DP01 All-In-One Recording Package...
Cannot unlock
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Nov 23, 2007 | Kenwood KDC-C469FM 6-Disc CD Changer
Open Questions:
See all Fostex MR16HD/CD Digital Recorder Questions
Fostex MR16HD/CD Digital Recorder Logo
251 people viewed this question
Top Fostex Televison & Video Experts
Michael Galve
Michael Galve
pawnpower
Tom Chichester
Are you a Fostex Televison and Video Expert? Answer questions, earn points and help others
