Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Problem for Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with...
I have a new Frigidaire 20.6 cu. ft. top freezer
By pgssjko on Oct 20, 2009
I have a new Frigidaire 20.6 cu. ft. top freezer without icemaker. When it turns on or goes in its cycle it makes a knocking sound behind freezer compartment, then stops. is this normal? . P.C Richards salesman says its normal. Older fridges never made this sound. Salesman says its because its "high efficiency.
Best Solution
posted on Oct 22, 2009
Helpful)
turbo_1784
Rank: Guide
Rating: 95%, 2 votes
This is normal. It is the sound of the refrigerant flowing through the coil on start up. This will cause the knocking sound you are hearing. It should only last for about 7-10 seconds. You might also hear a cracking noise due to the insulation expanding and contracting due to fluctuating temperature. Refer back to your owners manual under normal operation sounds. Hope this helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" thanks for the help. I don't think I ever buy another frigidaire. " - pgssjko
Popular Solutions for Frigidaire 20.6 cu. ft. Top
Questions and Unsolved Problems for Frigidaire 20.6 cu. ft. Top
Do you recommend Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker?
Answer
Answer
The freezer is frosting (frostfree) and the refrigerator is not cooling
Answer
i moved my refrigerator on its side and now it won't get cold...why?
Answer
I've got A Roper RT185DKXKQ00 which cools great but when it cycles on you can hear what sounds like... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire 20.6 cu. ft. Top...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
