Tv picture going green
I have a 80cm Akai CRT Television which after a while of being on goes green in colour. Picture is not fuzzy and still clear but the only colours are green,black and white. Even white is a green colour.
  • bradwinlee Jan 07, 2008
    Sorry, but I'm not a techo to take off cover of TV and check boards. I don't even know what a resistor looks like. Can you or anyone provide some "non techo" options for me to try, besides leaving it powered off at the wall for a day??
  • 149 Answers
Hi there, you have a color section or video section problem, check the crt board, there may be and open resistor or jumper, check those transistor driver too. check the small board at the back of the crt tube, do some test and see any cold solder. ty
Posted on Dec 29, 2007
Have a akai tv that's has a green or yellow tint
Check the picture tube base card for any loose solderings. Your TV lacks Blue colour putput. Check all the solder points on this board. Resolder all the susepected solder terminals [especially take care to blue output section], by applying a little more solder. Check the base connection solder terminals of the blue output transistor. It might be loose, or transistor is defective.
Mar 29, 2012 | Akai Televison & Video
What you need to do is clean the CRT coolant inside the TV. Here is a forum that I SHOULD have read before doing mine:
I was lazy and not taking my time to take care in not dripping any CRT coolant and some got on my circuit board, ( I felt confident since I had changed the Blue CRT 2 years prior) and I was only able to see about 1 hour of the best viewing my TV has ever given me since it was new, it looked like a miracle had happened. My TV was "dull" as the best way to describe it, colors faded, kinda fuzzy. I briefly researched into it again to refresh my memory then jumpted right into not really taking any precautions. I got lazy and didn't take out the CRT's like I did the first time with the Blue CRT and paid the price for it. Let me tell you, theirs nothing worse than getting a perfect brand new like picture only to loose it and hour later because of carelessness. Take out the CRT's, take your time, label everything and take pics, the reward is WELL worth it. Oh ya, you can use Mineral oil instead of the coolant that they sell at stores. Its not conductive, and dose'nt damage the circuit board if u spill a little. I used Baby Oil the first time I did it and when I went back to change the green CRT this time around it was still crystal clear, no discoloration in the Blue CRT I had done 2 years prior. I hope your results come out better than mine did!!
Dec 29, 2010 | Akai PT5492S 54" Rear Projection...
Picture went completely fuzzy. What could the problem be?
The tv CRT( picture tube) have a radiaton posion infected in ur tv picture tube.This is how u discharge the CRT(picture tube) get the posion out.Take the tv back cover off.Take video board that connected to the CRT(picture tube) out.Plug it in,so u have a live current to the CRT(picture tube).Find a wire like an AV cable,should be find.One side of the metal,grounded to the metal frame somewhere.Take a long needle plier grab the other side of the AV cable wire,not the metal,(Caution high voltage live current).Come very close to the open CRT(picture tube).U will have a live current arc,than u,will hear a big "POP".U,just discharge the CRT(picture tube).The tv now the CRT(picture tube),now it good,it clear of posion infected in ur tv picture tube.Now,unplug ur tv.Put ur tv,back together.Hook up ur tv signal cable and plug in ur tv,now ur tv picture,will be clear,completely.I do this many times to dicharge fuzzy CRT(picture tube).When i was a tv Tech.for the SONY TV Corporation.
Oct 12, 2010 | Sanyo HT32546 TV
Poor picture
adjust the antenna! or the cable connection could just be loose or dirty!
Jun 18, 2009 | Televison & Video
I have the akai model # ptf492s and the white colors are yellow
I'm almost positive the problem is you have fungus in the CRTs. I know this sounds strange, but it's true. Basically there is coolant fluid in the lamps that develops fungus over time and turns yellow. It should be clear. If you take the back off the television, you will see the 3 lenses (red, green, blue) Each of the lens is held on with 3 screws. Remove the adjustable lens and look at each CRT. Shine a flashlight in they should look white. From what I've read, blue develops the problem first, then green. You can replace the fluid. Look up TV coolant replacement online. It's not to difficult, but you cannot get any of the fluid on the circuit boards or it will ruin it. Mine had a lot of fungus in the blue CRT and a little in the green. The picture looks 100% better now. Good Luck.
May 12, 2009 | Akai PT5492S 54" Rear Projection...
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Probable bad tuner or tuner circuit issue, repair or bypass.....
If you can direct signal to A / V inputs as you are doing with your
DVD, then no repair is necessary.....utilyze cable box or VCR
tuner to change channels.......................T.
Dec 03, 2007 | Televison & Video
Rear Projection... Hitachi tv
humm.. could be a crt or a high voltage problem..flyback transformer or high voltage splitter... have a tech check it out for you.
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
