Was told we needed a thermostat with Aux heat. we have electric furnace with heat pump. There are eight wires (although the beige wire was not connected to previous thermostat) White wire is marked W2 and Black W3. We are trying to install new thermostat with aux heat, but can not figure out the wires. There is a W1 and W2 slot.
Standard hook up for Heat pump.
Red wire----------R
Green-------------G
Blue----------------C
Yellow-------------Y
Orange------------O
White--------------W1 with a jumper to E sometimes will also say Aux, varies with Manif. of T-stat.
Gday, I recently bought a Bonaire VSM 57 evaporative cooler on ebay. When the unit had been removed...
(More)
Gday, I recently bought a Bonaire VSM 57 evaporative cooler on ebay. When the unit had been removed the motor had been disconnected from the controller. Can anyone confirm the colour of the wires and connection into the controller? I can make out 3 of the four wires but the fourth is elusive.
I have an expensive Home Depot Fan (Hampton Bay) which has a lifetime guarantee. Home Depot has...
(More)
I have an expensive Home Depot Fan (Hampton Bay) which has a lifetime guarantee. Home Depot has asked that I contact your company (Aloha Housewares) since you're the manufacturer. The model number is FS21-45 and it has a Vendor number of 23827. It has worked for 10 years and now won't turn the blades. What should I do? I unplugged it when I smelt burning plastic! SKU: 458851. If I can't fix, I'll have to buy a new fan.
I have a Kelvinator KSR20G and the remote control does not work (I cannot switch on). What can I do...
(More)
I have a Kelvinator KSR20G and the remote control does not work (I cannot switch on). What can I do ? Where can I buy a new remote control ? (Brisbane)
I had this uit powered by a generator and think it took a spike and needed to know if there is a...
(More)
I had this uit powered by a generator and think it took a spike and needed to know if there is a reset switch inside the cover. I tried all the buttons on the front control panel no luck
My luxpro psd111 thermostat shows aux heat and the temperature in the house of not increasing. I've...
(More)
My luxpro psd111 thermostat shows aux heat and the temperature in the house of not increasing. I've replaced the batteries and filter, but don't understand or know why it's not warming the house.
