Question about Dryers
Bosch My daughter has a Bosch WTA3100 dryer. The on/off switch will not stay engaged. If you hold it in the dryer runs perfectly, but when released it disengages. I have had the top off but cannot see how to get at the switch to find out type, order new and fit. Any help would be much appreciated.
    Problem Solver:
  • 14 Answers
The switch unit on these washer driers has a habit of coming unclipped from th econtrol panel..try turning off the power and pushing on the back of the switch(pushing towards the front of the machine.)if it clicks you may have just repaired the prob.just dont push the button too hard.
Posted on Dec 29, 2007
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Kenmore electric dryer switch does not stay on
you will need to replace this switch as it has a relay on it and the holding coil that helps keep it running is open and can no longer keep the switch on or closed to operate the dryer
Aug 05, 2012 | Kenmore Elite HE4 Electric Dryer
Not sure of model but dryer does not stay running when switch is released. As long as you hold switch on it runs and when you release it shuts off. Suggestions?
Check the belt is not broken . If the drum turns when you start it then either the belt switch is bad or the motor switch is not working because it is bad or the motor may be full of lint.
Nov 17, 2010 | GE DBXR463EDWW Electric Dryer
Clothes Dryer won't stay on after switch is depressed.
some of them dryers have a switch other than the push button located behind the console. it also has an identical heat switch beside it. if that holding switch is bad it will not stay running. of the two identical switches the run switch is on the left. good kuck.
Jan 20, 2010 | Kenmore Dryers
Bosch maxx dryer
The manual for our Maxx WTL6500 says to press and hold the Start/Stop button for 4 seconds. "The child safety lock can be released permanently using the Menu button." In our case that means press Menu 3 times then press Change to set the lock on or off.
HTH
Jul 02, 2008 | Bosch Axxis WTL 6307 Electric Dryer
Bosch WTA 3100 Tumble Dryer ON/OFF switch
The on/off switch is combined with the door release switch in one item - part number 154145 (a little over £20) and my problem was the door interlock bit had failed. The following worked for me :
Plug out, remove top panel, and open door + look up at switch panel - you see 5 slots under the switch panel (the 2 outer ones are mostly covered by the main front panel). Start at either side and work across, using as wide-bladed a screwdriver as will fit across the slot width : put a wood block under blade as a support and lever bottom of panel towards front - each has a plastic pin behind pointing towards the rear, held by a spring clip. Each will pop clear and when all are unclipped you rotate the panel outwards from the bottom edge, taking the timer knob and its drive linkage with it. To get switch out I removed the door and the screws around the main front panel - one is hidden behind a cover plug below the access port (to gain access to bottom screws on main panel, lever the bottom panel outwards along its top edge).
Mar 09, 2008 | Dryers
Bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Feb 28, 2008 | Bosch Dryers
Dryers Logo
91 people viewed this question
Top Dryers Experts
