Sinks
Problem for Sinks
Generic problem for all Sinks
FITTING A BASIN
By vonnie_yvonn on Oct 20, 2009
how do i fit a karl basin from bathstore.com........i have no instructions.........do i need a certain tap ?
I WANT TO USE IT AS A MINI BELFAST SINK IN THE KITCHEN :)
Solution #1
posted on Nov 14, 2009
Not Rated)
Welsh Winger
Rank: Master
Rating: 100%, 1 votes
I am guessing you have the square one then. You need to fit your waste as normal, Send the waste through a hole in the surface you are placing the sink on and make your connections underneath. I use plumbers mait as a sealant when tightening the outlet. You then need to think about your taps. Since they are totally separate from the sink you can use what you want. Most people would use a monobloc riser though, secured to whatever surface you are laying the sink on.
You don't say how much you need to know about connections / plumbing etc. Please ask again if you are stuck with these.
Was this helpful?
Yes
No
Popular Solutions for Sinks
Questions and Unsolved Problems for Sinks
Answer
After installing a new disposal in an LG Highmax composite kitchen sink, a 120 degree crack appeared... (More)
Answer
I have a small chip in my clear black glass sink. How can it be fixed ?
Answer
i would like to know the trunk line please help me......because i want to talk to my father....his... (More)
Answer
hi just fitted a brand new mixer tap when i turn off hot or cold levers it can take up 30 seconds... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sinks:
Top Sink Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Sink Experts
Top Plumbing Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(866) 897-9936
316 2837038
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
