Question about Sharp 25J-M100 TV
Earphone Where do I plug in earphones?
  • 149 Answers
Hi there, some tv model have the option for earphones, others don't, ty
Posted on Dec 29, 2007
The hand set does not work I can not talk or recieve. but it will ring when a call comes in and leave information
Ok, here's my theory you used an earphone but it didn't disconnect. To know if this so if you see the earphone icon on your phone then that is the case. This happened to one of my phones. Anyway here is how you can solve this plug in an earphone and shake the plug gently while still plugged in. Take out the earphone. If the icon comes off problem solved if not.... .... Try again. It is usually because of the switch in the earphone jack that switches between headset and handheld mode becoming jammed. :) hope this solution helps
Jan 19, 2016 | Cell Phones
How can I plug earphones into this - which plug do you use?
Unless it has a plug for earphones it will not be an easy task. Most tvs only have line out (no volume control) or speaker out (rare) to plug in external speakers. Speaker outputs would be much to high to try earphones with. Line out will probably work but with no volume control unless you have it built into your earphones. You will also need an adapter to use the earphones with the line out.
Sep 09, 2015 | Televison & Video
Problem with my earphones.samsung shg-j700
go to options while you are listening to music & then select "earphone on"
Jul 24, 2012 | Cell Phones
The sound is coming out perfectly in the right earphone but it is barely coming out in the left earphone
Then you need to adjust the earphones plug in, adjust it gently and it will sound right on both earphone. It is the plug that is causing the problem. Adjusting it will solve the problem for you.
Jan 11, 2011 | ILuv Audio Players & Recorders
How to connect my computer audio to pioneer vsx515 reciever..
here the steps:
1. locate the earphone jack on your pc.
2. after finding the earphone jack from your pc you need a connector (baby stereo plug to 2xrca plug).
3.connect the baby stereo plug to your earphone jack and then the rca plug to your Pioneer axuliary in.
Jan 02, 2011 | Pioneer VSX-515 Receiver
Hi i have a 1st gen 16gb ipod touch. When i insert the earphones into the socket i either get no sound, very poor quality sound, or ok quality sound which disapears when i move. i think this is because of...
Some devices such as yours have a 4 conductor jack, (used for earphones and microphone) and most earphones have a 3 conductor plug. They are not compatible. This would be my first guess. Second is earphones and earbuds get tossed around, put into pockets, etc. The cords can get damaged, and not be visible from the outside as the wires inside are very delicate. I would try a set that works in a different device.
Dec 02, 2017 | Apple iPod touch 1st Generation (8 GB) MP3...
Won't detect a jack being plugged in
it doesen`t do that on my computer either but i still get sound
Apr 13, 2009 | Dell A215 Computer Speakers
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
Televison & Video Logo
67 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
