Question about Acoustic Research AW-721 Consumer Headphones
Acoustic research aw722
I just bought these wireless headphones and i do not have a headphone jack. So these headphones came with a Y red and white cable which connect to the front of the televison to the audio, but i still do not hear any sound in my headphones. The TV is still blasting sound and all I hear in the headphones is static they have charged for 20hrs or more already. Do i have the hooked up right, the Y cable is suppose to make the sound come into the speakers
  • 1 more comment
  • Gary Soucie
    Gary Soucie Dec 22, 2008
    Same problem, except I don't hear any static. I've also tried other fully charged batteries with same (ie, no) result.
  • tim46759
    tim46759 Apr 03, 2013
    adjust frequency on roller knob
  • Kurt Mathes Aug 26, 2014
Poop in a bucket
Posted on May 10, 2008
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Posted on Jan 14, 2008
Where can I order new headphone pads for my Acoustic Research AW772 wireless headphones?
The 90mm leatherette cussions from Scan Sound fit and are comfortable. They are round but stretch to fit.
Nov 29, 2013 | Acoustic Research 900MHz Wireless Stereo...
Sylvania wireless headphones
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more :
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
Read more :
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Jun 10, 2011 | Acoustic Research AW-772 Headphones
I have 2 sets of Acoustic Research AW722 headphones. Both sets of the ear cushions' leatherette outside material have disintigrated. I cannot find any replacement parts anywhere. The size of the...
I just purchased and installed a pair of 90mm leatherette headphone cushions from Scan Sound (LEC90) it took about 10 min to insall them (they are round but stretchable) They are very comfortable.
May 06, 2011 | Acoustic Research 900MHz Wireless Stereo...
I need ni-cad battery specifications for Acoustic Research AW-721 headphones. I bought replacement ni-cads but they don't charge when the headphones are placed on the headphone cradle/charger.
The AR AW721 headphones require 3 AAA NiMH batteries, not Ni-Cad. The original batteries are 1.2 volt, 550 mAh. I replaced mine with Energizer 850 mAh AAA batteries, which work well and actually last longer per charge than the originals.
Sep 20, 2010 | Acoustic Research AW-721 Consumer...
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
Hook up wireless headphones
hello im sure you dont have the instruction you dont need it....firs hook up the transmiter you have to connect power end signal transmit what you wanto to listen
the signal comes from phones out,audio out rca and this sound travels in air via infrared wave to you headphones hope i help..
Jan 17, 2009 | Electronics - Others
Operating manual
After connecting all cables.... try channel 1 at the receiver... then move tuner up and down until the green light on the left headphone lights up and you can hear whatever you are listening to. If channel 1 doesnt work, try 2 and 3...... mine is set on CH3.
Good luck
Oct 31, 2007 | Acoustic Research AW-721 Consumer...
Acoustic Research AW-721 Consumer Headphones Logo
749 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
