Question about Whirlpool Duet GHW9150P Front Load Washer
F 26 Code that won't go away
My front loading washer has had an F 26 error code 3 times now since we purchased in in Sept. when this code appears the washer is totally out of commission until a repair person comes and clears it. I can't find this code anywhere in the manual, nor on any help sites, so can someone please let me know what the process is to clear this code so I can use my washer. It's Sat on a holiday weekend so getting someone to come and fix this will be a long wait... Please help...
Thanks much
The F26 error code on the Duet washer is a door switch error. The button inside the door opening might be stuck so that it doesn't register as being opened and closed. First press the pause/cancel button to clear the error display. Next push the button inside the door opening a few times and pull it so that it pops out completely. That should solve the problem.
Posted on Jul 09, 2009
  • Mollie Pigg
    Mollie Pigg Oct 16, 2013
    Thank you, thank you, thank you!! I have unpugged it and hit pause/cancek and waited and repeated all the steps and cleaned everything. So frustrated til I found your advice. Very much appreciated.
    New Friend:
Rassman-you just saved me time and money waiting and paying for a service call. I cancelled my program, jiggled the door button and and the machine started right away!
Gotta love the internet!
Thank you so much!
Posted on Jun 18, 2013
You can clear codes by hitting pause/cancel twice f26 indicates an electrical promblem that your feild technican is supposed to contac whirlpool about i got friends there and wiil call after new years but i need your complete model num and serial number my e mail is b4829@yahoo.com im tech17 but having trouble logging into this site right now could indicate a ground fault in your house or your outlet not polerized right something till i get you an answer just hit pause cancel twice
Posted on Dec 29, 2007
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Error code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
At the end of the normal wash cycle my washer begins to beep repetitively and shows an error code of F 02?. It will not spin and drain. We've began to switch it to Drain/Spin cycle and this works about...
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 30, 2011 | Washing Machines
What is the error code dS for Neptune Maytag Washer MAH8700AWW?
Please advise me on any recalls and technical information involving error code 3E during a wash load, which appears related to be a faulty control panel. My machine is always shutting down each time it reaches the rinse cycle. Numerous consumers have been complaining about this same model at consumeraffairs.com. Replacement of the control panel is expensive at an average cost of 298 dollars and appears to be the corrective action for other consumers with error code 3E. Over current is not being detected at the motor. I'm disappointed with the quality of this washer considering I purchased it in 2005 for over 1,000 dollars. This problem has forced me to use a local laundry mat to wash my clothes. This error code is not listed in the User manual.
Aug 24, 2010 | Maytag MAH8700A Front Load Washer
My washer added more time to the load and when it was done LE appeared on the screen. I tried to wash the next day and it does not turn all the way.
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Aug 02, 2010 | LG WM-2277HW Front Load Washer
Model LGWM2277H purchased 2005 - Since 3/19/10 LE Code Continues
Thank you !!
Jul 18, 2010 | LG WM2277H Front Load Washer
LE code is flashing when I try to run the machine
Thank you !!
Jun 25, 2010 | LG WM2277H Front Load Washer
Hello, I'm getting and Error Code F24, does anyone
The "F24" error code is a heat sensor error code. The following link explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
In many cases, the connector plug on the NTC sensor wiggles loose and causes the error code. Check the NTC connection first to make sure it is tight and making good contact. This may save you a service call and/or replacement parts. Make sure you UNPLUG the washer before servicing anything inside the unit.
A replacement NTC module (if required) can be purchased at searspartsdirect.com for about $10. The part number is 8181705. Refer to the parts illustrations under the "Tub and Basket Parts" heading for item 26 as a pictoral reference to assist you in locating the sensor on your washer.
If you have any questions, please let me know. I hope this helps you.
Dec 08, 2009 | Maytag EPIC MFW9700S Front Load Washer
OE ERROR CODE APPEARS ON DISPLAY ON MY LG FRONT LOAD WASHER
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages
Oct 14, 2009 | LG WM-2277HW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
5,509 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
