SOURCE: white LCD on my canon
Hi: I think you have broken (accidentaly with the fall) the cable with several wires that connect the LC display. My real advice is that you take your camera to a store were they can give you direct support desmanteling the camera and replacing the cable or fixing it. However, Zair already had a problem like yours and the best solutions was given by BowerR64. You can consult on the following page: http://www.fixya.com/problems-solutions/t103443,p294056/Canon-PowerShot-G2-Digital-Camera.aspx (just copy and paste on the address bar) ;) Regards
SOURCE: LCD screen black with white specs in picture and movie mode
Know this is an old post, but really this sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
SOURCE: 6 beeps, something strange on LCD, won't take photos
I'm sure 6 beeps means something but with the Canon makes their manuals they never tell you what it means.
Here is the complete owners manual for the product in case you don't have one:
http://gdlp01.c-wss.com/gds/0900001188/PSA540_530CUGad-EN.pdf
The troubleshooting section starts on pg 89.
If that section doesn't help you, Best Buy may have a solution or any camera in your area can help you.
SOURCE: Canon S215 viewfinder and lcd display screen blk
There is a temporary fix that works sometimes but eventually it will stop working alltogether. If canon can't help, might try this:
http://cgi.ebay.com/Repair-blank-black-pictures-S2IS-canon-powershot-S2-IS_W0QQitemZ300293064869QQcmdZViewItemQQptZDigital_Cameras?hash=item300293064869&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
SOURCE: Canon S2 IS - LCD screen is white after taking an outside picture
the image is all white or has lines through it.Definitely sounds like a repair issue, and has been a previous problem with the camera in the past. There is a defect in the sensor of the camera, and happens quite frequently in this model. I would try and contact Canon about it, and see if they'll repair it for free. If not, its probably going to cost more than the camera is worth to repair it.
