Question about KitchenAid KHWS01PMT Front Load Washer
F02 code I'm getting fault code 02 . It takes us several turns before it spins properly. please help
    President:
  • 1,314 Answers
Thats long draining time first check the filter on the pump get a shopvac and vacum the drain hose with the door open till you hear you have all the water out of the washer will make different sound if you dont have shop vac get raditor hose clamp from auto parts store clamp hose going up to tub after you remove the two screws from the front bottom kick plate inside you will see the pump and the hose to clamp if you didnt vacum remove the filter by turning the round plastic piece on the front of the pump see if a forgien object is interfearing with the pump or if the impeller blades are broken if they are replace the pump if not and no foreigen found ckeck the drain hosek for blockage if you used clamp dont forget to take it of before replacing kick plate
Posted on Dec 29, 2007
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How can fix f 02
whirlpool duet f02 codeHow to fix fo2 fault code on a whirlpool duet front load washing machine, The whirlpool duet is one of the machines that have a main computer control that operate and monitor the functions of the machine,
This control is usually mounted behind the front panel,sometimes at the back or to the side, it also has a speed control board that is mounted on the bottom usually at the right side.
Whenever a problem accur there is a fault code displayed on the machine, there is a technician sheet with the fault codes on the machine, the technician can use this guide to go directly to the problem,
This f02 code mean there is a problem with the drain, there is a drain filter that sometimes get clogged with lint and other things,
Removing the kick plate and removing the drain access on the pump will reveal the drain filter, use a small bucket, and towels to catch the water that will be in the pump
Nov 26, 2012 | Whirlpool duet Washing Machines
F 02 code. washer won't drain properly
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When it gets to spin cycle, it does not do it. it shows a 02 fault error
Hi panchopepe,
The F02 error code is a long drain issue. The pump is usually blocked with lint, coins, etc... Check the filter in the pump and clean it out. This should fix your problem. Also make sure that you are using the HE detergent and not the regular detergent as this will cause a sudsing issue. Hope this helps you out.
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
At the end of the normal wash cycle my washer begins to beep repetitively and shows an error code of F 02?. It will not spin and drain. We've began to switch it to Drain/Spin cycle and this works about...
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 30, 2011 | Washing Machines
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Oct 24, 2009 | Kenmore Elite HE5t Washer
Get error code f02
Long Drain
to resolve
  • If the above does not correct the problem, replace the pump.
Mar 02, 2009 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Fault message
Yes, F02 is a fault code, and is indicating a problem with the motor, it means that the motor is jammed, or the tacho is broken or detached. The tacho being a magnet on the end of the motor away from the pulley.
You will have to remove the motor to see if you can see anything obvious.
If you cannot sort it yourself, then I would recommend that you call an engineer.
You would not find an explanation for this error in the handbook.
Please rate my fixya solution.
Thanks.
Feb 07, 2009 | Indesit W 123 Front Load Washer
HELP!!
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
KitchenAid KHWS01PMT Front Load Washer Logo
155 people viewed this question
Top KitchenAid Washing Machines Experts
gbob59
Eric Taylor
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
