Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
I have xerox work center 415 and always give error J3 (it mean the cartridge is not install) I am sure I put the cartridge correctly I am sure I put the cartridge correctly but it give the same error, and I check the weir which connect the cartridge to the mother bored it was ok But the problem still there Pleas help me
  • 119 Answers
Try to restart
Posted on Oct 20, 2009
It shows j7 after replacing a new drum catridge
Posted on Apr 26, 2011
How do i fix error bk-crum error 093-925 - using geniue carttidges
If you have just installed these cartridges and got this message immediately, Make sure that these are the correct cartridges.
The cartridges for the Xerox 6180 are identical to look at, but have different part numbers, and crucially different chips.
There are also pagepack/Eclick versions of these cartridges.
If your printer is a 'pagepack' version of the printer, it needs pagepack/Eclick cartridges, and will give an error if normal cartridges are used. Similarly, if your printer is a 'normal' version, and you put a 'apgepack/Eclick' cartridge in it, you'll get an error.
If you've had the cartridges in the printer and used it WITHOUT getting the CRUM error message, the counter chip has become corrupted. This can happen if there is a power problem during a chip 'write' operation.
The error message points to the Black cartridge.
Sep 22, 2014 | Xerox Genuine Phase 6280n 6280 6280dn...
Hi sir i have a xerox dc 12 giving error code 10-500 after replacing a new web cartridge
This code means that printer is not detecting the cartridge. you can try to to remove it and re seat it or it could be faulty, her is a list of all of the codes.
http://www.metrouk.co.uk/pdf/xeroxdc12faultcodes.pdf
Hope this helps.
Sep 16, 2014 | Xerox DocuColor 12 Printer
Xerox workcentre m24 replace toner even if the toner is new
There is no need to worry a lot what you can do is that, just open the toner access door located at the front of the printer and then you can scroll down the list of cartridges until you find the one which is giving you the message of Replacing toner.
Then press the button "1" to reset the display toner settings. If still you find any of the difficulties then we have a best place available which can actually sort out your issue and they are Micro Toner Supplies and their official website is where you can find a lot of things is https://www.microtonersupplies.com.au/toner/xerox-toner-cartridges
Basically these guys(Xerox Toner Cartridges) are famous for supplying cartridges at a specific cost and to your mentioned area but in this site there is a contact option available where you can contact them and can solve you issue. Hope this may work to you and if still you find any difficult even after accessing the prescribed website then there are many other websites where you can find better solutions.
Aug 30, 2014 | Xerox Office Equipment & Supplies
Installed new toner cartridge into the machine. Still getting the J3 error
Toner cartridge and J3 are two different things J3 is jam code something is not correct in the paper path.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 16, 2013 | Minolta EP1031/1031F CS/PRO Copier
What does check process unit mean
According to http://www.partsdrop.com/info.php?info_id=Pro645inf the error message is shown on the webpage, are you sure the toner cartridge is the correct one
Dec 09, 2011 | Xerox WorkCentre Pro 765 Laser Printer
Print cartridge error
This means that the catridge is not placed correctly in the printer. or there is some problem in the catridge...
Aug 30, 2009 | HP PSC 1315 All-In-One InkJet Printer
Xerox workcentre 4150 printer cartridge not installed correctly
i'm going to try to explain this in english even tought is not my native language, i had the same problem with my xerox 4150, when i bought a new cartridge it worked perfectly but at some point it stoped working, and it says in the screen something like "remove toner cartridge and reinstall", the problem was that the chip (is like a sticker under the toner) was in bad position from factory, a men who worked in xerox told me that there was a lot of toner cartridge that came with this problem, and this chip is ultrasonic or something like that because it never make contact with the printer circuit, so the fact is that you only have to remove and re-paste the chip in the correct position, but you have to do it several times until it works, that's how i repaired it...
Aug 26, 2009 | Xerox Office Equipment & Supplies
J3 error On Xerox WorkCentre Pro - 215
A J3 means the toner cartridge is not compatible. That is the what the J3 message means.
Make sure the correct cartridge has been installed. For example, a Pro16 Toner Cartridge looks very similar and will fit in the machine, but it will display a J3 fault. Install a known correct Toner Cartridge if you suspect the cartridge in the machine is the problem. If the wrong Toner Cartridge has been used, the correct cartridge needs to be ordered and installed in the machine
It is possible the chip on the back of the cartridge is bad. Have you tried reseating the cartridge? Maybe it is just loose.
Dec 19, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Need help
Hi
you havenot installed drum cartridge properly inside the machine or you have installed the drum cartridge of Xerox 5816/5821.
Hope you will do it.
Sep 18, 2008 | Xerox WorkCentre M118 Black and White...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
402 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Clive
Clive
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
